Question about Car Audio & Video
Rover 420 radio wiring
Hi just bought a rover 420 and someone has chopped the radio wires i have connected the red wire and the yellow wires up and the radio cd makes a noise then stops but nothing else happens if i connect the red and the yellow wires up the radio works but loses memory every time i turn it off also this runs the battery down can anyone help thanks
  • 78 Answers
SOURCE: kenwood kdc 3011 rests its self every time i turn the car off
This means that the power lead you connected the red and yellow to is a switched live and each time you turn off the ignition the power goes off and therefore resets. to fix this problem you need to connect the yellow to a permanent 12v supply that stays live when you turn off the ignition.
Posted on May 28, 2008
  • 33 Answers
SOURCE: Yellow Wire has no power
Your stock radio should have had a wire that does this. It may not be yellow so look up the wiring diagrams for your car. If you can't find it by doing that, then look up a diagram of your use box. Sometimes there's a diagram on the back of the fuse panel cover or somewhere around there that tells you what fuses are from what. You can then run a new wire if you have to.
Posted on Jan 08, 2009
dj x
  • 61 Answers
SOURCE: every time i try to hook up my cd player to my
this can be one of three things
1) the fuse on back of CD player could be blown
2) you need to push and hold the src/pwr button till unit powers on
as long as the yellow and red wire are attached to the positive battery wire you are good if the ground is to the battery ground and you try the first two steps i said and nothing happens........
3) ground the black wire from back of the CD player to any metal surface on the golf cart than try the first two steps again
it should power on if this is the case
hope i was able to help you
Posted on Mar 06, 2009
etirbynnor
  • 655 Answers
SOURCE: ok, here is a list of the factory wires coming
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Posted on Aug 12, 2009
Testimonial: "thank you greatly. that does help alot."
SOURCE: diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Posted on Oct 06, 2009
Hi i have one of your radio units in my 04 range rover but i have to set my mobile up to your unit every time i get in the car, is there a wire i have to connect to a constant 12v live.
Yes, the yellow wire needs to be on a "hot at all times wire". The yellow one is for memory in the radio. You can connect it to any power wire under the dash. It uses very little power and amperage.
Mar 02, 2015 | 2004 Land Rover Range Rover
Radio wiring code for 1987 mercedes benz 300. With aftermarket radio the windows switch ligths blinks and have no instrument ligths.
Hi, the aftermarket stereo does not use the illumination wire. You must tape that wire off (purple/gray). That wire is either connected to the wrong place or is touching chassis ground and causing your instrument lights to dim.
Connect the stereo's red wire to the car's black/yellow wire; and connect the stereo's yellow wire to the car's red/white wire.
1987 Mercedes 300E Car Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Black/Yellow
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Purple/Gray
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre Dash
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Black
Right Rear Speaker Positive Wire (+): Green
Right Rear Speaker Negative Wire (-): Black
Sep 13, 2011 | 1987 Mercedes-Benz 300-Class
Installing aftermarket Kenwood stereo on 1991 Subaru Legacy. The subaru stock wiring does not have a red ignition wire. Can i simply connect the kenwood ignition wire to the Accessory +12v (Yellow/red)?...
Hi, according to my source, there should be an accessory wire that is blue with a yellow stripe. If your is yellow/red, that's fine. You actually should prefer an accessory wire to an ignition wire as there may be less static on the accessory wire. Just make sure the wire does not have power when the key is off. Don't use the illumination wires--they are not needed for the aftermarket head unit and should be taped off.
1991 Subaru Legacy Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Green
Car Radio Switched 12v+ Wire: Blue/Yellow
Car Radio Illumination Wire: Red
Car Stereo Antenna Trigger: N/A
Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Black
Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
May 31, 2011 | Car Audio & Video
JVC KD-R312 CD player keeps resetting itself whenever the ignition is turned off. The radio stations are ok, but mybass, treble, loudness etc always resets itself. Is annoying because i ahve to go through...
You are losing the permenant 12VDC on the Radio. This is the thick yellow wire from the radio loom, it has to be connected all the time to 12VDC.
Cheers
Oct 27, 2010 | JVC Car Audio & Video
We cant find the power cable in our rover 420 sdi to re-wire a new stereo..the blocks have been cut off the stereo we brought so no clue as to wats wat and no wire diagram on top of stereo
If its a aftermarket stereo, the red wire is ignition, yellow wire is constant 12 volts, & black wire is ground. The speaker wires should be purple + & purple w/ black stripe - / white + & white w/ black stripe - / green + & w/ black stripe - / gray + w/ black stripe - /....then blue is for power antenna. Thats most aftermarket radios, some have orange for a dimmer but it depends on the brand.
Mar 28, 2010 | Pioneer DEH-P6600 CD Player
Ive wired a new radio in my land rover but the speakers will not play
Have you tried connecting different wires together ? i think the speaker wires are white, blue, purple, and brown in most cars make sure you hook up the positive to positive and negative to negative ..... negative will have a black chopped up line all the way down the wire. Hope this helped
Oct 30, 2009 | 1995 Land Rover Discovery
My car radio has to be reset every time the car turns off
i don't know what kind of car that you have but on that radio there should be two power wires one is red and the other is yellow,the red wire connects to the wire in the car that will only have power when the key is turned to the on position,the yellow wire connects to the wire in the car that always has power with the key off.........
Jul 01, 2009 | Panasonic CQ-C1303U CD Player
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
