Question about PNY Attach? 16GB USB 2.0 Flash Drive
My computer thinks my pny 32GB USB 2.0 flash drive is a disk
My Pny USB 2.0 FD USB Device is coming up as a disk drive from having a partition put on it after it being formated to FS=NTFS through command prompt and i do not know how to reverse it.
  • 3 more comments
  • nos482
    nos482 Dec 11, 2012
    Edite: DISKPART> SELECT DISK 1> CLEAN> CREATE PARTITION PRIMARY> SELECT PARTITION 1> ACTIVE> FORMAT FS=NTFS> ASSIGN> EXIT is what i did in command prompt and now I don't know how to undo it.
  • nos482
    nos482 Dec 11, 2012
    also wont let me format it through disk management or from my computer folder says it is unable.
  • nos482
    nos482 Dec 11, 2012
    PNY Technologies 32GB Metal Attache USB 2.0 Flash Drive
  • Jose Diaz
    Jose Diaz Dec 11, 2012
    Could be you don't have enough rights or is right protected, especially if the format was on a another account. Both can be checked by right clicking.
  • nos482
    nos482 Dec 11, 2012
    same method to change it back, same account, and it worked to change it in the first place, but now wont let me change it back... I h8 technology -_-
  • 2,878 Answers
All pen and SD cards show up as removable hard drives. Removable or not they can be treated the same. You can format again just by right clicking on it, or use diskmgmt.msc to fully manage via the MS management console.
It's basically doing the same as you did from the cmd prompt.
If you asking to restore files, then you require a 3rd party software. There is Recuva (free), Wondershare, and Stellar. They all do the same thing.
Posted on Dec 11, 2012
Pny Attache 64gb flash drive will not format correctly
You can go to Administrative Tools>Computer Management>Disk Management and try to format it from there. You may need to delete the partition that is on there and create a new one. If you are still unable to format the drive correctly, contact the manufacturer and request a replacement.
Mar 14, 2014 | PNY Attache 64GB USB Flash Drive
PNY Attache 64GB usb flash drive Disk is write protected
Normally I'd make something this simple the very first step. Some USB flash drives come with mechanical switch on them that put them into Write Protected mode.
There can be very small slider switch.
And if this is the case, then you must move the switch to unlock position.
Source: http://www.rescuedigitalmedia.com
Oct 01, 2012 | PNY Attache 64GB USB Flash Drive
How to remove 'write protected' from PNY Optima Pro Attache 2 GB USB 2.0 Flash. My flash drive named above, always tells me that the drive is write ptotected whenever I want to add or remove a...
If it doesn't have a sliding "write protect" switch on it as shown in step 2, try step 5 or step 6 on this page:
http://www.makeuseof.com/tag/how-to-fix-write-protection-errors-on-a-usb-stick/
Small sd cards have a small slider in the case itself. Flash drives may have partitions on the drive itself. One or two of these small partitions may have write protection on them that cannot be removed. If you have too much trouble, put the flash drive in a usb slot, wait for it to be recognized. Open the control panel and open administrative tools. Click on computer management and then in the left lower pane, click disc management. In the right pane, there will be a window that shows and lists all the drives and partitions. Look for your flash drive and you can delete volumes, partition the drive etc.
remove write protected from PNY Optima Pro Attache 2 GB USB 2 0 Flash...
Mar 05, 2018 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Last year I copied photos onto my 1GB PNY Attache Flash Drive. I've viewed the photos several times, so I'm sure the photos copied correctly. Now when I put in the flash drive, my computer says 0 files....
Hi
Please follow these steps
1. I think its not a problem with flash drive.
2. There should be virus in your computer.
3. Please install anti virus or if it is already there update it.
4. I think that virus is deleting your files in the flash drive.
Jul 30, 2010 | PNY Attach? 1GB USB 2.0 Flash Drives...
I am trying to download a WMA Audiobook from the library site Wilbur, but it says that my PNY USB 2.0 FD USB device is incompatible
if it doesn t read your card. Its because the computer or labtop can not read HC high capacity cards. it will read a 1 GB or 2 GB but anything above will not be read. check on card if it has HC you need new hardware or a regular sd card.
Mar 29, 2010 | PNY 4GB Secure Digital High Capacity...
Pny attache optima pro 8g usb drive disk space problem
Yes, and Perfectly too.
What you should do is,
depending on your operating system,
Right-Click on 'My Computer Icon', then select 'Manage'.
When you get to Computer Management page,
Click on Disk Management on left hand side,
This will display ALL the disks installed on your system, either partitioned or not partitioned, formatted or not formatted.
Then go to the ones that are hidden, not created, or not displayed, right-click on it, then you'll see different actions that you can perform.
Also, in some instances, what you just need to do when you get to this page is to assign a new, distinct, drive letter apart from the ones already in use on the system.
This will automatically bring out the hidden drives.
Hope I have helped you out.
Goodluck
Oct 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Wen i put my pny usb 2.0 drive in my computer doesnt read it
put it on another pc then check if it works or not if yes then format your card and ckeck it on your computer, i think its your flash drive problem.
Oct 12, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Pny 16gb attachi flash drive reccognized by my computer but says insert disk into drive when I left click it
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 14, 2009 | PNY Attach? 16GB USB 2.0 Flash Drive
PNY Attach? 16GB USB 2.0 Flash Drive Logo
447 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
