Question about Creative Labs MuVo Slim MP3 Player
Mp3 trouble file system error
When i start my system i get a file system error whats the problem
  • 1 more comment
  • Gilberson Storck Dec 09, 2007
    I have the same one, however the message that's shown is: Error (41).
    There is a way in order to avoid this trouble: Start to play your MP3 by folders - you can explore it and to choose the option "play now". It's work with me. It's boring way, but....it works!
  • nanref Feb 07, 2008
    how to reformat a muvo slim ? pls pls
  • chocospidey Jul 01, 2008
    When I start the player I get a msg 'File System Error'. I tried reformatting it but it doesn't get formatted in Vista and the device cannot be recognized by Windows XP. What do I do ?
U should try reformatting it. thats usually solves the problems
Posted on Aug 10, 2007
coolfixya
  • 82 Answers
SOURCE: the mp3 player says file system error when i go to music
COnnect the mp3 player to computer via USB cable and format it by right click and format in MY computer..then again put mp3 files into it..
Posted on Feb 28, 2009
yboyandrei
  • 828 Answers
SOURCE: FILE SYSTEM ERROR
i think your mp3 player have its own program, file system error have all symptoms maybe in your windows system or in your mp3 player software, heres a tip: install a firmware of your mp3 player, run the scandisk or defrag your MP3 player... if the error exist try to insert your mp3 player to another computer to check if the problem is exist.
Posted on Jun 23, 2009
SOURCE: my coby mp3 mp610-2g says file system error when
Boot up with linux, erase partition on protable device. reboot into windows, go to control panel system administrative tools, computer management, storage, creat new partition on drive, reformat drive using software that came with your device. this should repair the problem. it worked on mine!
Posted on Jun 26, 2009
SOURCE: file system error on my philips SA32XX mp3
why don`t my philips sa32xx download videos anymore
Posted on Nov 28, 2009
SOURCE: Spi Mp3 file system error
Have ou found a solution yet? Because mine is doing the same thing. Could you please email me if you have found a solution and tell me what to do.
Thank You.
Drama_wanda@yahoo.com
Posted on Jan 07, 2010
Hp 6930p nmi channel check iochk
System I/O address specifications 970-071 NMI enable/RTC
What is Nmi Error On Hp Server error? The Nmi Error On Hp is the Hexadecimal format of the error caused. This is common error code format used by windows and other windows compatible software and driver vendors.
This code is used by the vendor to identify the error caused. This Nmi Error On Hp Server error code has a numeric error number and a technical description. In some cases the error may have more parameters in Nmi Error On Hp Server format .This additional hexadecimal code are the address of the memory locations where the instruction(s) was loaded at the time of the error.
What causes Nmi Error On Hp Server error? The Nmi Error On Hp may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Nmi Error On Hp Server error? There are two (2) ways to fix Nmi Error On Hp
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Nmi Error On Hp Server) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Dec 10, 2016 | HP Computers & Internet
Sim 3 into the future installation
What causes Extended Attributes Are Inconsistent Error Message error? The Extended Attributes Are Inconsistent Error Message error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
How to easily fix Extended Attributes Are Inconsistent Error Message error?
There are two (2) ways to fix Extended Attributes Are Inconsistent Error Message Error:
1) Download (Extended Attributes Are Inconsistent Error Message ) repair utility.
Jan 20, 2014 | Computers & Internet
Critical errors
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
Delete some stubborn files
http://www.malwarebytes.org/fileassassin.php
Oct 15, 2013 | Webroot Computers & Internet
Error 42126 RAR Archive is corrupted
you might be able work your way through the problem You could run the chkdsk disk utility
Windows 7 chkdsk
also you might need to delete some stubborn files
Jul 29, 2013 | Microsoft Windows XP Home Edition
How do you fix error 2400
http://www.registryquick.net/page/RegistryQuick_setup.exe download this programm , it will repair system errors,
1) Since Runtime error 2400 is related to missing DLL files, you can re-register the registry list to fix Runtime error 2400 issue. For example, if you encounter Runtime error 2400 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:windowssystem32dllfile Download Repair tools
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
2) To fix Runtime error 2400, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 2400, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 2400 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
May 31, 2011 | Computers & Internet
I cant pull up my yahoo mail. It keeps giving me an error code 13030
13030 error are usually caused when the operating system's registry contains errors or when certain system files are missing or broken; 13030 error problems are a sign of a very unhealthy system. 13030 error are caused in one way or another by misconfigured system files Click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen when you restart your computer then defragment your hard drive
do not do anything while chkdsk is in process any input may damage your computer
or you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps don
Mar 12, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I just purchased router WRT 120 N during the installation I am getting the error 322
HI there,
To fix Runtime error 332, you should understand the concept of Runtime error 332 and identify the causes of it firstly. What is Runtime error 332? This error usually occurs when a DLL file is missing, or not registered on your computer. It is a really common problem for windows users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can re-register the registry list to fix Runtime error 332 issue. For example, if you encounter Runtime error 332 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile Download Repair tools (http://www.registryquick.net/page/RegistryQuick_setup.exe)
#2 To fix Runtime error 332, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix Runtime error 332 and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 332, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 332 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
Dec 20, 2010 | Linksys WRT120N Router
OpenOffice Error
Try this. Search for a file on your system called common.xcu. If you find that file, rename it to common.xcu.old and restart OpenOffice. The common.xcu file should be rebuilt automatically and (hopefully) everything should work.
If that doesn't fix the problem, let me know what version of OpenOffice you have and what OS you're on and we'll dig a bit deeper.
Eric Imboden
http://commoncontext.com
my take on tech : http://redsquiggly.com
Oct 22, 2008 | Sun OpenOffice
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
Nov 26, 2007 | Creative Labs MuVo V200 MP3 Player
Creative Labs MuVo Slim MP3 Player Logo
118 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
