SAMSUNG GALAXY YOUNG GT-5360
My Dear Brother:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: i forgot pattern unlock for
ou can Check Master Reset Code here http://www.mobileunlocksolutions.com/unlocking-services/rs1wp6/ To Unlock Your mobile from the Security or Password Lock,I unlocked My Mobile using the Master Reset Code,You can Check Master Reset Code for Your model mobile in the List there....
SOURCE: my samsung galaxy europa gt15500
dont type the full gmai,l for example [email protected] is wrong,just type giga1234 as username. same problem happened to me...i continusaly typed the full gmail account and it didnt accept. so just tyoe ur username..
SOURCE: i need to reset my
Android operation systems have you set-up a Gmail account when you first activate them. This GMAIL automatically backs up contacts, calendar, and of course e-mail. Once you try the unlock too many times it will have you sign into it. If you don't remember then you will have to Manually Master Clear it and start all over. LMK if this is the case.
I’m happy to assist further over the phone at https://www.6ya.com/expert/steven_958e67a4edcc47d5
SOURCE: hi i have a samsung
The only way to get around this is run the recovery
How to do this
1. Turn off the phone
2. Told down the UP Volume button and power button
3. Wait till the screen comes on and then off
4. A menu shows up and click restore/recover
5. The password is gone.
how to unlock pattern lock of samsung galaxy y gt s 5360 solution
