Question about Intel Pentium 3 , 450 MHz Pentium III (SL364) Boxed Processor
Driver for USB port on my Intel Pentium II machine
The USB port is in place and the new hardware is recognized but it does not appear in Explorer presumably because the driver requires updating. I would like to download the appropriate driver. Can you Help?
  • 2 more comments
  • Kunnath Jan 15, 2009
    Windows ME
  • bled_haruni Jan 29, 2009
    I have
    Intel Pentium 2 , 400 MHz. and i had installed xp professional s2. USB ports doesn't works. How can i do?
    Thanx
  • Dick
    Dick May 11, 2010
    Which operating system?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you know what the make and model number of the mother board on you computer is?
  • 2,794 Answers
Thats a tough operating system to get support from. If you can find out who the manufacturer of the motherboard is you could try a windows 98 driver for it. If you can find a way to put Windows XP into your computer, that would make it easier to take care of it.
Posted on Jan 15, 2009
    Sergeant:
  • 270 Answers
Try it in manufacture website.
My lan driver not work
Go to the following link, select your operating system then download it & install. http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Desktop+Chipsets&ProductProduct=Intel%C2%AE+865+Chipset+Family
After installing, right click on My computer, Hardware, Device manager. Check Any thing in yellow color in Network adapters or in any place. If it is related to network then, re-install Operating system & try. If nothing is in yellow color then the Ethernet port i.e., LAN port is gone bad replace the same & insert new LAN port in other slot i.e., PCI slot & install the driver & check. I hope it will work for you.
Jan 24, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
USB device malfunction
i) try to connect pendrive to the usb ports present at backside of ur computer tower instead of usb ports present at the front panel of ur computer...............
ii) sometimes usb ports present at the front panel ofur computer might have loosen connections............
Thanking you
M. Sridhar
Jan 18, 2009 | Intel Motherboard
USB Driver for Intel Pentium II
I received a message from someone else who wants to know the make and model of the mother board to my P II Machine. If he cannot help me solve the problem, I shall revert to you.
Jan 13, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Usb port not working
If you have Vista check M/soft site for bulletin 940199
Vista has a habit of losing USB ports and there is a fix for it
Aug 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Software for USB Controller
check bios enable usb, xp has usb drivers. if still not working, buy add in card, onboard usb may be damaged! i have seen this before many times! also you can try to contact acer,but they are often not helpful! good-day!
Jun 13, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Im using a serial to usb connector to connect my artZ II tablet to my laptop..
Sorry, I figured it out, it was because the serial to usb adapter i was using needed a driver, and then my computer recognizes it as an extra serial port. So, during installation it needed to be searched for automatically from my serial ports.
May 12, 2008 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Need specs on ax6b mb
CPU: Intel Pentium III / Intel Pentium II / Intel Celeron slot1
ASIC: Intel 440BX AGP set
Architecture: 3 xISA slots + 4 x PCI slots + 1 x AGP slos
Max. Memory: 1 GB SDRAM for DIMMx 4
DIMM Type: 8/16/32/64/128/256 MB
BIOS: AWARD plug-n-play flash ROM BIOS
On Board I/O:
2 serial ports (UART 16C550 supported)
1 parallel port (SPP/EPP/ECP supported).
2 floppy drive supported (1.2/1.44./2.88 MB)
2-channel IDE (PIO Mode 4 and ultra DMA/33 bus master supported)
2 USB ports supported (universal serial bus)
1 PS/2 Mouse Port
1 PS/2 Keyboard Port
On Board SCSI: Adaptec AHA-7880P ultra wide SCSI controller
SCSI Port: 68-pin wide SCSI and 50-pin FAST SCSI connector yes
Battery: 3V lithium battery
Green Function: Yes
Connector: IrDA, Wake On LAN, SB-LINK,Wake On Modem
Board Size: 244 mm x 305 mm, ATX form factor
Apr 13, 2008 | Computers & Internet
Mouse not being recognized
Hello Narin,
Check the USB properties if there are some errors at Control Panel> System> Device Manager> USB device. Install the compliment CD driver for USB devices. Also try placing the mouse into other USB port(s). Update your OS as necessary for device patches and if there's a need to install driver for the said mouse please install then.. Hope thos helps.
Best regards,
Rosener Guyano
Feb 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
Wndows NT on pentium II
Up to service pack 4 at least..for Win2k. Are you really trying to do anything with NT 2.51 still??
Oct 22, 2007 | Computers & Internet
Intel Pentium 3 , 450 MHz Pentium III (SL364) Boxed Processor Logo
419 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
