Question about Symbol PPT 2740 Portable Terminal
How can I obtain scanning software for a symbol ppt2740
Memorycard pasword remove
. *#4720# -Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
*#4720# -Deactivate Half Rate Codec.
3. *#0000# -Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
4. *#9999# -Phones software version if *#0000# does not work.
5. *#06# -For checking the International Mobile Equipment Identity (IMEI Number)
6. #pw+1234567890+1# -Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
7. #pw+1234567890+2# -Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
8. #pw+1234567890+3# -Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
9. #pw+1234567890+4# -SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
10. *#147# -(vodafone) this lets you know who called you last.
11. *#1471# -Last call (Only vodofone).
12. *#21# -Allows you to check the number that "All Calls" are diverted to.
13. *#2640# -Displays security code in use
14. *#30# -Lets you see the private number.
15. *#43# -Allows you to check the "Call Waiting" status of your phone.
16. *#61# -Allows you to check the number that "On No Reply" calls are diverted to.
17. *#62# -Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
18. *#67# -Allows you to check the number that "On Busy Calls" are diverted to.
19. *#67705646# -Removes operator logo on 3310 & 3330
20. *#73# -Reset phone timers and game scores.
21. *#746025625# -Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible.
22. *#7760# -Manufactures code.
23. *#7780# -Restore factory settings.
24. *#8110# -Software version for the nokia 8110.
25. *#92702689# -Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
26. *#94870345123456789# -Deactivate the PWM-Mem.
27. **21*number# -Turn on "All Calls" diverting to the phone number entered.
28. **61*number# -Turn on "No Reply" diverting to the phone number entered.
29. **67*number# -Turn on "On Busy" diverting to the phone number entered.
30. 12345 This is the default security phone lock code.
Nov 18, 2011 | Nokia 7610
My samsung corby s3850 is freezed and lock from other networks what should i do? will restoring factory setting fix it?
Samsung Unlock codes are in another post. If u find any difficulty to understand this Unlock code for Mobile Phones please write in comment section. 2) *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type. ( Favorite ) (3) *#9999# Phones software version if*#0000# does not work. (4)*3370# Activate Enhanced Full Rate Codec(EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5% If mobile is locked you can check by this way (8) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the"p,w" and "+" symbols). (9) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the"p,w" and "+" symbols). (10) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the"p,w" and "+" symbols). (11) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the"p,w" and "+" symbols). Hope it will helps you .
Jul 11, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My samsung tocca lite keeps saying limited service it is unlocked to any network i cant seem to get any to work it is on o2 could you help me
Samsung Unlock codes are in another post. If u find any difficulty to understand this Unlock code for Mobile Phones please write in comment section. 2) *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type. ( Favorite ) (3) *#9999# Phones software version if*#0000# does not work. (4)*3370# Activate Enhanced Full Rate Codec(EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5% If mobile is locked you can check by this way (8) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the"p,w" and "+" symbols). (9) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the"p,w" and "+" symbols). (10) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the"p,w" and "+" symbols). (11) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the"p,w" and "+" symbols). Hope it will helps you thanks
Jul 11, 2011 | Cell Phones
Hello i want to unlock my nokia 6300
Master reset code is :- 3547514211
Rate this solution fixya.
Aug 30, 2009 | Nokia 6300 Cellular Phone
How to open ristriction code of my t mobile nokia 5310 xpressmusic
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
Aug 30, 2009 | Nokia 5310 Cellular Phone
Symbol handheld scanner problems
scanners are just plug and play.. be sure the scanner is programmed to read the type of bar code you are scanning.. Check the symbol to make sure it is not defaced. Try scanning test symbols of the same barcode type. and last tip, move the scanner closer to or further from the bar code.
Aug 11, 2008 | Symbol LS2208 Handheld
Phone lock code
  • To check IMEI press *#06#.
  • To check the Software Version press *#170602112302#.
  • If Imagine the cell battery is very low, and an important call is expected what to do there is a a reserve battery in the absence of the charger then to activate the key and recharge the cell again is to press "*3370#".
  • #3370# To deactivate Enhanced Full Rate Codec( EFR).
  • *#4720# To activate Half Rate Codec.
  • *#0000# It displays the software version of the phone.
  • *#9999# To check the phones software version if *#0000# does not work.
  • #pw+1234567890+1# To check the Provider Lock Status. ( "*" sigh to obtain the "p,w" and "+" symbols).
  • #pw+1234567890+2# To check the Network Lock Status. ( "*" sigh to obtain the "p,w" and "+" symbols).
  • #pw+1234567890+3# To check the Country Lock Status. ( "*" sigh to obtain the "p,w" and "+" symbols).
  • #pw+1234567890+4# To check the SIM Card Lock Status.( "*" sigh to obtain the "p,w" and "+" symbols).
  • *#147# vodafone this lets you know who called you last time *#1471#.
  • *#21# Allows you to check the number that "All Calls" are diverted.
  • *#2640# It displays the security code.
  • #30# It lets you see the private number.
  • *#67705646# It removes operator logo on 3310 & 3330.
  • *#73# It reset the phone timers.
  • *#746025625# It displays the SIM Clock status.
  • *#7760# Manufactures code.
  • *#7780# Restore factory settings.
  • *#92702689# (to rember *#WAR0ANTY#).
  • Mar 19, 2008 | Cell Phones
    Symbol PPT 2740 Portable Terminal Logo
    Top Symbol Computers & Internet Experts
    Michael
    Oloyede Monsuru
    Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
