Question about Philips 42PF9630A 42 in. Plasma Television
42PF9630/42PF5321 Power Light-No A/V
There is athe power light on the set but no A/V.I had gotten advise from fixya that the power supply was bad on this set. I found a new PS and replaced it. It ran fine for less than 24 hours. Something else is causing this failure. Any ideas? Thanks
  • 3 more comments
  • jayess60 Jan 13, 2009
    No, the power light(green) remains steady. When the problem reoccured the a/v came up briefly and went out. After I repowered the set I could hear the PS click but still no a/v. Thanks
    The green power light remains steady (no flashing).
    I purchased a service manual which told me how to access the helpdesk mode. The only error code that came up was 04. When I went into this mode the a/v came up temporarily and then went back off as if there was a thermal issue.
    This TV (Phillips 42PF5321D/37), stopped displaying video and audio. It has just a steady green power light with NO flashing lights. I had posted the problem a couple of weeks ago and was advised that the PS was faulty. I found and replaced the PS, which worked for 3-4 hours until I shut the TV off. As soon as I powered on the set this morning it ran for 1 minute and lost a/v. After I posted the problem again this morning I received a terse answer that I should have gotten a service manual to troubleshoot the problem. I thought that was why I came to you guy's in the first place. Anyway, after buying the manual and reading about the helpdesk option I got the tv up long enough to get an error code of 04. The tv again went off after 5 minutes or so. I don't know how to interpet the error code. THX
  • Anonymous Apr 27, 2009
    I have the same issue a green light that stays on but no picture or sound. but in the back of the set on the powerboard in the middle there is a green led that flashes 4 times then reflashes 4 times.
    Master:
  • 623 Answers
ONE: Try a hard reset. This will correct any software code if it got corrupted in some way. Merely unplug the power cord for 4 hours or more. Then power it up again. If the reset does not cure the problem it means there is a hardware failure of some kind. Probably within the controller IC (Integrated Circuit) which controls all the user functions.
TWO: If the hard reset does not correct the problem you could use external speakers. Using the headphone as an audio output it can be fed to an external amlifier/speaker. You can purchase stereo speakers with subwoofer (they are commonly used for personal computers) for $19 and up. They will just plug in simply to the tv and will give adequate sound quality. Maybe better than the original sound.
THREE: If you call in a service tech it will cost at least $100 or more.
Posted on Jan 13, 2009
    Genius:
  • 1,011 Answers
Dear,
At the PS section, the two capacitors can be caused this. check its functionality and physical status. most of the times, the capactior burning can be viewed at once.
regards,
dont rate it until u satisfies
  • SALMAN NASEER Jan 13, 2009
    dear,
    most probably, they are 10 or 16 V capacitors
    check it by the way
    Genius:
  • 1,239 Answers
Hi
On the CRT circuit board(picture tube), you will find R3340, which is a 10 ohm 1/3w resistor. The location of the resistor is printed on the bottom of the ckt board. It is burned open, replace with a 10 ohm 1/2w resistor. This will solve your problem. The original resistor was sized too small, should have been a 1/2 watt.This resistor is mounted standing up on ends. Mount the replacement resistor the same way. You can probably get the resistor at your local Radio Shack. You will probably have to buy a package of 5, but what the hey . . . they are cheap.
Be careful and don't get the circuit trace too hot and damage the circuit trace. (it's very small)
Good luck.
  • ABHISHEK.C
    ABHISHEK.C Jan 13, 2009
    The most likely cause of this problem is a bad lamp.  Replace the lamp and all should be well again.  In fact, you will be amazed at how much brighter the picture is after the lamp has been replaced.
  • ABHISHEK.C
    The converter have failed, or there is a problem with converter wiring/connector. also test backlight system.
    The inverter must be tested, and eventually replaced.
    On australian models four blink is PSU fault on 5V.
    If you are in US is backlight fault
    Brigadier General:
  • 8,619 Answers
Hi!
The loss of picture is due to defective display driver circuit.
  • 679 Answers
Check out the main fuse.
and let me know.
  • 15,935 Answers
Please repost the original problem in full
  • 2 more comments
  • blueextc3221
    blueextc3221 Jan 13, 2009
    Since you feel comfortable using the service menu you may want to go and clear the error, and watch for it to happen again. Use the Reset Error Buffer menu item to clear it.
  • blueextc3221
    Have you updated the firmware?
  • blueextc3221
    http://www.p4c.philips.com/files/4/42pf5..." target="_blank" rel="nofollow" >CLICK HERE to d/l zip file with your Firmware Upgrade.
    or HERE to go to the site directly for download.
  • blueextc3221
    I read somewhere on the Philips site that some TV shutdown issues can be caused by electrostatic charge buildup? And that could be remedied by unplugging the TV for 10 minutes from time to time.
    Make sure your thumb drive is formatted in FAT only. Not FAT16 or FAT32. That should get it going.
    It's either FAT16 or FAT32, and your USB thumb drive must be FAT32 formated to work.
    Put your thumbdrive in a computer, and click on "My Computer" icon. You should see your thumbdrive. Right click on the thumbdrive icon and select Properties. It should say File System: FAT32. If it says anything else, then it will NOT work.
    Remember that you have to unzip the firmware file you downloaded from the internet, and then copy the unzipped file to the USB drive. It will NOT work if you don't unzip the file first
  • 837 Answers
Is the light flashing?
  • Philips Master
  • 19,396 Answers
If you have no blinking code you need to buy the service manual and follow the troubleshooting diagrams to find out what is the defective component that is blowing the PSU.
Before replacement the old PSU should have been tested.
Backlight Inverter Repalced still not working
dim the lights in the room, turn on the set, and shine a bright flash light on the screen. Do you see a faint picture? Also be advised that there are a lot of bad parts floating around on EBay. No backlight condition could be cause by a bad main board, power supply, inverter board, high voltage short on the inverter output, or a bad backlight bulb.
Nov 07, 2013 | Toshiba Regza 42RV535U 42 in. LCD HDTV
It wont turn on at all
Good day to mam wendy311!!!!
If you TV is totally dead set and no red light or green light on the front...
if that so the problem could be cause of dead set power power supply board...
You have 3 choices its either repair it on your own or took it to the technician or buy a new set of power supply board..
But for me I suggest to buy a new power supply board because if you took it to the technician cost of repair is almost or higher depends on the bad parts than the new power supply board...
But before you buy a new PSU please check this simple and common parts that usually cause of dead power supply board..
  1. Transistor----Check if shorted
  2. Capacitors----Check if bulged or leak.
  3. Resistors----Check if open or change value..
  4. Fuses---------Check if busted..
I hope this solution will be helpful..
Thanks for using fixya...
Aug 12, 2011 | Apex Digital LD4088 LCD TV
My Sony Bravia TV won't turn on, a red light flashes twice every few seconds but nothing happens., the screen is still black. Please advise what i need to do asap.
Tries tv unplug,replug it back like about an hour later.The tv will be resetting back to the factory setting.Now the tv should be working again.If it have the same result.The power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 13, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The TV will not turn on. No power light
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Jun 22, 2010 | Protron PLTV3250 32 in. LCD Television
Power supply light has blinking green light
If the power box is bad, The computer will not come on. if you only get a green light, you would need to start with replaceing the power box, if you get a new one and the same thing happens, then the mother board is bad too.
Nov 26, 2007 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Problems with JVC AV-32WR4EK
This could denote a power supply problem. or overcurrent protection due to a component going bad. If you do not have electronics experience, "DO NOT TRY TO WROK ON THIS SET" people have been seriously hurt trying to repair TV without knowing the basics of electronics. If this is a power supply problem it may be the HV supply and the switching power supply (IVHT based) or the low voltage starter supply. In both cases I would advise you taking it to the shop for repairs.
Sep 18, 2007 | JVC AV-30W476 30" TV
Philips 42PF9630A 42 in. Plasma Television Logo
596 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
