Question about Mitsubishi Televison & Video
My WD-60639 DLP TV won't stay on (it goes off right after it gets on)
The TV will not stay on.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
You should be getting a light or lights on set blinking in this case, and the set should have a self check if they blink etc---hold menu and input in at same time for more than five seconds and release both, the blinks on the power light should be a two digit code like three blinks, seven blinks which is 37 Let me know what if any code you find.
If you unplugged the set during this time it will clear the errors so you have to try to turn it on again, let it fail and do the check again.
SD TECH
Posted on Dec 11, 2012
  • 2 more comments
  • John Boumparis Dec 14, 2012
    Thanks for your assistance.
    The TV set goes on for a few seconds and then it switches off. No light indicator will fron there on blink. There seems to be no response. Is it possible to have a faulty lamp that is causing this problem?
    By the way the TV is the Mitsubishi WD 60638 !
  • SD Tech
    SD Tech Dec 14, 2012
    Yes a lamp could do it, look to see if you can see the lamp fire up or not and I have one other piece of advice, when all these first came out I encountered what seemed like a odd issue, shutdown with no blink code etc, in our shop when working they are on a cart, I would remove rear cover and roll set outside(we have a loading bay) and with a compressor dust the set out, any dust on the fans etc can also do this, had more than one that when dusted out suddenly worked again perfectly---I would not do inside the house as it may look like a dust storm when you do it, I know its winter in many areas but consider doing it.
5 Suggested Answers
SOURCE: WD-62725 DLP TV Automatically Turns Off
Its usually your DM control board!!! it needs to be replaced!!!
Posted on Apr 08, 2008
  • 38 Answers
SOURCE: mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Posted on Dec 24, 2008
  • 1779 Answers
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Posted on Feb 14, 2009
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
On my Mitsubishi WD-82840 DLP TV for the first hour of operation I'm seeing green pixelations in the darkest sections of the image displaying on the TV.
May mean the DLP chip is either not getting the proper level of black signal until the controller board has warmed up, or the DLP chip itself is not completely responding to the controller signals. After thoroughly warming up the problem goes away. This is a sign of aging of the parts. Diagnosing and correcting that type of problem is a challenge. Regards.
Dec 07, 2015 | Mitsubishi WD Televison & Video
The timer light is continuosly blinking when i plugging in the tv (mitshubishi wd-5252) and won't reset?
Thats one of the famous capacitor issue most likely. Thats the V26 Chassis DLP and usually that symptom is caused by failed DM and Power Board capacitors. There is a repair kit that will work in alot of cases with that symptom. Its called The V26 Chassis DM / Power repair kit available at the following link with detailed instructions http://tvrepairworld.com/mitsubishi_repair_kits
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Lost screws
Well, if it won't turn on, the problem is more than just a screw.. you can get screws at any hardware store, just take one in there and ask them to find one that matches it. As for your TV not working... it may be the power supply.
Jun 08, 2012 | Mitsubishi WD-65738 Medallion 65 3D DLP...
Four buttons on dash for 4 wd. won't stay on 2 wd and it goes back to 4wd by itself
Sorry, but three possibilities. Most likely the 4wd actuator motor on the transfer case went bad. This is pretty common. They also encounter switch problems, but it sounds like your switch is doing what it's supposed to. One more thing, there is a 4wd control module, usually in the right kick panel. I'm betting on the shift motor though.
Sep 03, 2011 | 2000 GMC Jimmy
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP overheating
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mar 29, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
