Question about Nikon D5000 Digital Camera
Lens locked The lens will not rotate on my camera and therefore will not focus so all pictures are blurry. Is it possible that I could have locked it somehow or is it broken?
    Problem Solver:
  • 5 Answers
Very
Posted on Dec 11, 2012
bschilz
  • 2049 Answers
SOURCE: took a picture, then camera was in bag for a
What you're experiencing is called a lens error. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 18, 2010
Testimonial: "Good trouble-shooting! Helpful link. Thank you!"
  • 17 Answers
SOURCE: When I change my focus
Auto mode is the point-and-shoot mode. It is not the camera problem. It is a common problem amongst nikkor kit lenses. Get your lens checked to the dealer, or any Nikon customer care. If its under warranty, it'll be replaced.
Posted on Aug 06, 2010
  • 11967 Answers
SOURCE: I have a Nikon S210
Sounds like a lens problem. Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 17, 2010
  • 11967 Answers
SOURCE: My nikon S610 doesn't auto focus. When i turn it
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Posted on Oct 13, 2010
SOURCE: my nikon coolpix s202 had
Hi,af motor or its gears locked for a small particle (sand grain i.e.).Need cleaning.
Greethings
Posted on Feb 19, 2011
Blurry pictures
You did not say which lens or lenses you are using, but most auto-focus lenses have a switch for selecting manual or auto-focus. First, check your camera's menu settings to make sure auto-focus is enabled and then your lens to make sure you did not accidently leave it in the manual focus position? If it is in the auto-focus position and still not taking sharp pictures, switch it to manual and see if you can get it to focus correctly. It is also possible that your auto-focus alignment is out because your camera was bumped, jolted or dropped. If realignment is necessary, you can send the camera and lens to Nikon for repair or find a knowledgeable camera repairman.
Jul 29, 2012 | Nikon D5000 Digital Camera
Tip
Blurry Photos
Good day,
I have heard a lot of complaints about people taking Blurry Photos.
There are a few possibilities for it and a few easy fixes.
The first possibility I would identify is a dirty lens. To fix this simply take a clean microfiber cloth and gently clean the lens until there are no smudges visible.
The other possibility I would identify is that the pictures are out of focus.
This problem can be caused by a dirty lens or because the object or person was not focused on. To ensure focus on your photos, line up your shot and wait for the camera to focus by pressing the shutter button half way down. When focused press the shutter button in all the way and hold the camera still until the photo appears on the screen. By doing this you will eliminate any motion that might mess up your shot.
Please let me know if these tips work for you!
Regards
on Nov 29, 2010 | Cameras
Why are my pictures blurred
This depends on your camera but there are many reasons your pictures could be blurry.
1. Your lens is dirty. Most obvious answer but I'm assuming you already checked this.
2. Your shutter speed is too long. It should be as fast as possible based on the amount of light you have available. You can likely change this in your camera's settings.
3. Your lens is out of focus. Either manually focus it (if possible) or make sure the lens is set to autofocus in the camera settings.
It would be easier if you mentioned the model of camera you had. Those are the best possible answers I can give without knowing anything else.
Jul 24, 2012 | Cameras
Pictures are blurry unless I push the picture switch down very slow
Good day,
Regards
Mar 18, 2011 | Canon IXUS 80 IS Digital Camera
Blurry pictures
Good day,
Regards
Feb 20, 2011 | Polaroid a300 Digital Camera
The pictures comes blurry :(
Good day,
Regards
Feb 19, 2011 | Nikon COOLPIX P100 Digital Camera
Blurry pictrues in coolpix s51
Good day,
Regards
Feb 16, 2011 | Nikon Coolpix S51c Digital Camera
Hello my name is Julian and would you mind giving me assistance on helping me with my, logitech webcam because,it's blurry?
Hi, 1) You try reducing your webcam settings to high or low, to see the best possible settings to enable better quality images.
(or)
2)This may sound a bit crazy, but try to rotate the lens (the white part around the lens). Your camera has a manual focus, so you have to twist it until you get a clear picture. I have a similar one, so what I do is I point it at a book and rotate until I can read the book clearly on the monitor. Alternately, you can buy a more expensive camera with auto focus.
Hope you understand.
3)Thanks for using fixya..
Dec 05, 2010 | Logitech Webcam
My webcam is blurry
Rotate the ring around the lens to adjust the focus until you get a sharp picture.
Mar 21, 2009 | Radio Shack VGA PC Camera Webcam
I can't get the camera to focus
Did you try adjusting the lens? The rim of the camera is actually a focal lens. Try to adjust that by rotating it clockwise and counter-clockwise and see if there's clarity.
Feb 18, 2009 | Microsoft LifeCam VX-3000 Web Camera
Nikon D5000 Digital Camera Logo
24 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
