Question about Asko W6021 Front Load Washer
Asko washing machine door not closing
We cannot close our Asko washing machine door. We have tried to set and reset child lock but this appears to not be the issue - any helpful hints?
  • Anonymous Mar 29, 2014
    Machine cannot start because door is not closed. How to reset the sensor
  • Anonymous Mar 31, 2014
    I have tried to open and close door to no avail
    President:
  • 1,294 Answers
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
I'm trying to start the asko washer for the first time and I can't get the door to lock. the start button is blinking??
HI there, the door on my front loader was very hard to close, but the service people told me to close it really hard - slam it! and it has been fine ever since.
Jan 02, 2011 | Asko W6021 Front Load Washer
Hi, my front loader washing machine (Bosch Logixx 8 sensitive) has child lock written on the screen and will not start the load. ive tried switching it on and off again but it does nothing. the door is...
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Dec 22, 2010 | Bosch Washing Machines
Asko front load washing machine
The door lock mechanism. You have to quote your model and number while ordering.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Mar 31, 2009 | Asko W660
Try some WD40 on the door mech,(on door, ie.) And with switch off, close & open door 4 or 5 times.
May 09, 2008 | Asko W6021 Front Load Washer
The door on my asko w6021 wont close
Hello
Well I'm sure you have power on machine if not check fuse located at rear of machine below lip.
Next step remove top cover a cheap saftey screw driver set
will do trick not standard drivers.Electrical drawing is located
inside,Photo copy,now locate a cheap multimeter for testing,
don't worry it's not rocket science.Look closely at cables notice all cables have numbers printed.If PWR lamp above switch is on proceed as follows.
Remove power from machine & test on the Ohms scale between
E111 & E113 if you have resistance great i can't remember value! Now put a bridge wire between E121 & E111with closed door should lock when machine is turned on ,if not you can test between V Volt scale ac & you should read about 30 Volts ac Between E113 &E111when you press door release button on front of machine.
Note the switch LB in drawing represents front door you can also
check across this on Ohms scale with no PWR.
Regards
May 02, 2008 | Asko W6021 Front Load Washer
Using asko washer front load
Close the door firmly.  It won't start until the door is sealed shut.
Dec 10, 2007 | Asko W6441 Front Load Washer
Asko W6021 Front Load Washer Logo
1,339 people viewed this question
Top Asko Washing Machines Experts
Marvin
Marvin
Sal De
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
