Question about Microwave Ovens
How does the bulb inside the micro wave come out is it a screw in one?
Unable to get bulb out to change
    Top Expert:
  • Microwave Ovens Master
  • 14,553 Answers
It will vary from unit to unit what type of lamp or bulb is used, You might do one of several things--read the owner manual as instructions are often there, if a major brand call customer service with the model number.
Search With Google for the manual with the model number and look on You Tube who often has video instructions based and model, brand or general description of what you want to do: :"how to replace the bulb in my microwave" etc.
Posted on Dec 11, 2012
MicrowaveSvc
  • 9047 Answers
SOURCE: delonghi combi/micro bulb not working , how do i change the bulb
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 07, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Jenn-Air micro-wave oven serial number #JMV8208AAS
This is the door latch, and replacing it is not a bad job for a do-it-yourselfer, in case you or someone you know may want to do it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You have to separate the door panels (as shown in the attached photo) and then you'll see how you can replace the broken door latch. (Don't lose the spring!)
Or you can watch a YouTube video (not a video I made) that demonstrates how it's opened.
If you don't want to do it yourself, you can find your nearest Jenn-Air / Maytag-authorized servicer here.
They generally charge about $75 to visit the home, $75-90 to do the repair work, and the part may run about $15 or so. If nothing else, you can save about $75 by taking it to the shop yourself.
I'd suggest a helper for that task, and you can download installation instructions here.
Posted on Nov 08, 2008
  • 23 Answers
SOURCE: my handy man hung my micro wave by putting a screw
Ugh, "Handy Men" If he put a screw through the cabinet along with installing it the proper way just for extra stability, then no big deal. But if he used the screw as the main way to mount it, he shouldn't be pretending he knows what he is doing. Someone that kind of knows what they are doing sould be able to hang the microwave the right way in a half hour to a hour max. Some of us that do it regularly can do it in about 10-15 min after the old one or vent hood is out. If you don't have the proper bolts down through the cabinet, no it isn't safe.
Posted on Jun 20, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: micro wave works but light burn out how doI change
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Bulbs (and 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 31, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker Micro/Oven Need to change
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 20, 2010
The inside light bulb that works when the door opens and food is cooking is burned out, I have the new bulb but don't know where to replace it.
Brand and model would help but I'll guess at this. If micro is a wall hung unit over the range, you usually need to remove the top grill assembly above the door. Then look inside directly above the area where the bulb is located. You should see a metal cover with usually 1 screw in it to remove. Once screw is out that metal plate usually pulls forward and upward to reveal the bulb and socket. Replace bulb and reverse procedure to assemble.
If the micro is a counter top model---the complete outer case usually needs removed if you don't see a small access door by the bulb. Remove all screws around back edge and any screws in the side panels---then lift back edge and pull outer case rearward to remove.
Jun 03, 2015 | Microwave Ovens
How do I change the light bulb in a KCM155j Mircowave
Most microwaves have a shield over the light bulb in the cooking compartment. Some are accessed from the outside most from the inside. Check to see if there are clips or screws that need to be removed to pull the shield off. Careful if there are screws, they are usually coated to prevent the waves from arcing if you crack or break off the coating you could have problems with the microwave arcing
Jan 11, 2014 | KitchenAid KCMC155J Convection/Microwave...
Need to replace light bulb inside ge sca1000 microwave
The service manual is here.
Dec 15, 2011 | GE Microwave Ovens
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
How do yo change a blown light on a NN-T774SF micro wave
just disconnect from the power and take out the screws from the cover around and you will see a plastic color white then remove a screw from them and you find the bulb replace and return all parts back
Apr 01, 2011 | Panasonic NN-T774SF Microwave Oven
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave works but light burn out how doI change
Jan 29, 2010 | Daewoo KOR-1B4H Microwave Oven
I like my micro wave. However it is working without light. You know the light turn on when it is working. So, I worried about it has some possibilty of wrong.
You might find an access panel inside the oven. If so, remove it and change the bulb. Otherwise, you will have to remove the cover to get to the lamp.
Thanks for your interest in FixYa.com
Dec 11, 2009 | Microwave Ovens
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
How to change the bulb in a jes1288sh02 ge microwave oven
You can find an exploded view showing the the lamp assembly (location refer# 280) here.
You can order the lamp assembly by entering your full model number here. It is part # WB36X951.
Jan 15, 2009 | GE JES1238 Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
