Question about Watches
Battery type fossil 2573???????
Battery type for watch Fossil CH 2573??? Thank you.
  • 14 Answers
SOURCE: new fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
Posted on Dec 05, 2007
SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Posted on Nov 09, 2008
  • 203 Answers
SOURCE: How to Change battery Diesel DZ7040
dont do it yourself it will invalidate the warranty bring it back to the shop the should replace the battery free of charge. it might be more than the battery. if this helps please rate. joe
Posted on Nov 22, 2008
  • 16 Answers
SOURCE: How to change my battery on my fossil watch?
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
the type f battery will be written on the battery and you can usually find them at a drug store, hardware store or jewelry store that sells watches.
Posted on Jan 23, 2009
escapement
  • 2334 Answers
SOURCE: How do I replace a battery on a kenneth cole watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Posted on Feb 28, 2010
Ch-2331 battery replacement for fossil blue
Take your watch to a jeweler for battery replacement.
Jan 30, 2017 | Fossil Watches
What battery does the fossil ch2599 watch take
You are going to have to remove the battery to find out which one you need. For instructions on how to do this see: http://www.mademan.com/mm/fossil-watch-battery-replacement-guide.html. You can buy the battery at: http://shop.batterymart.com/search#w=fossil%20ch2599%20watch%20battery. Replacing a Fossil battery is delicate and tricky. Fossil recommends that you send it to a shop that specializes in Fossil watch battery replacements.
Feb 25, 2015 | Fossil Watches
INSTRUCTION MANUAL FOR FOSSIL CH2698
See https://www.fossil.com/content/dam/fossil/PDF/watchinstructions/Fossil_Watch_Instructions_EN_US.pdf
The file is a compendium of instructions for a large number of Fossil movements, but it is unclertain which movements the model CH-2331 and CH-2698 watches use. However, movement OS10 (page 15) appears to be the only one that matches the dial layout, button layout and also has a date window as the CH-2331. The watch has a quartz analog mechanism and uses one SR927W 1.55-volt silver oxide button cell. Silver oxide cells have low current output, but very long shelf life, so if the stem is pulled out completely when the watch isn't being worn, the battery could last many years. Scan the instructions to match up the CH-2698 with a movement number. A good guess from examining photos of the face of a CH-2698 watch would be movements OS20 / FS00 or VD53.
Apr 07, 2014 | Fossil CH2331 Wrist Watch
What type of battery for a fossil ch-2532
Take your watch to a jeweler to identify type and possibly replace it.
Mar 01, 2014 | Fossil CH2331 Wrist Watch
I need setting directions for a fossil watch model ch-2203
Thank you for contacting FixYa.
You should be able to contact Fossil at following link for directions/manual to your watch.
http://www.fossil.com/en_US/shop/customer_care/static/fossil-warrantyRepairs.html
Best wishes. Jewel
Oct 02, 2010 | Fossil Watches
I don't have the original battery to my watch, and am looking for a replacement. The watch is a Fossil Arkitekt FS-3031
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</A></P><P>Best regards.</P>
Aug 24, 2010 | Fossil Watches
Battery
mcdevito75 here, It may be a 364 or a 377 It"s not so easy, many styles of Fossil watch out there.
Jul 14, 2010 | Fossil FS3042 Wrist Watch
Looking for battery for Fossil Watch Style # FS4317 Watch for Men
Link
Hi mm01891,
Please browse above link for your fossil battery replacement. Kindly refer this matter to your authorized Fossil dealers.
Thank you
May 24, 2010 | Fossil Watch Style # FS4317 Watch for Men
ES9439 Wrist Watch: what battery doe the Fossil ES9439 Wrist Watch tak...
Link
Please visit above link for your Fossil battery requirement. Kindly contact Customer Service Team for further details.
Thank you.
May 18, 2010 | Fossil ES9439 Wrist Watch
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Watches Logo
43 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
