Question about Minolta DI2510 Black and White Copier
Double side to single copy w/o paper feeder
Work in doctor office and we make copies of insurance and driver license, front and back. How can I do this without using the paper feeder on a bizhub di2510
    Genius:
  • 1,605 Answers
In the touch panel, touch orig>>copy, select the desir function "sigle-sided>> double sided" this function will produce a double side copy from two single sided documents.
Posted on Jan 13, 2009
  • Minolta Master
  • 2,794 Answers
Try this.
Set the copy for duplex.
Put the drivers license on the glass.
press the start button.
Turn drivers license over.
Press the start button.
Should copy on both sides of sheet.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
I need to copy my license front n back of it on the same side of the paper how do i do it
Copy the front of your license on a piece of page. Take that piece of paper, put the back of the license facing up beside it and copy this page.
Good luck,
Paul
Jan 25, 2016 | Office Equipment & Supplies
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
How do you scan a double sided document?
You put your papers into the document feeder, then on the LCD screen there is a button that says 2 sided. Touch that button and select what you need. If you have a bunch of single sided pages that you want 2 sided then select 1,1-2. If you have a bunch of double sided pages that you need copied then select 2-2 and then puch the copy button.
Oct 11, 2011 | Sharp MX-2700N Color Copier
When 2-sided copies are made using the feeder,
hi just clean the paper path to solve the problem
thanks
May 11, 2010 | Canon imageRUNNER 5000 Copier
How to make duplex copies from toshiba e-studio202L
I am going to assume you have a document feeder (ADF) on the copier.
Insert originals into document feeder and press the 1-1 simplex button on the LCD screen. If have single page documents that you want to turn into double sided documents then select 1 - 2 button. If you have double sided originals already and want to make double sided copies then select 2 - 2 button. Then hit the green copy start key...done.
Jan 17, 2010 | Toshiba e-Studio 202L Copier
Cannot print double sided
On the machine when a 2 sided document is inserted in the document handler, select the 2x2 button on the console. Press the start button and the machine will feed the document in, and do a reverse of the document for the second scan. In the paper feeder, the machine feeds the paper in and reversed the copy back into the machine, flips the copy then feeds the copy back for the second side to be copied.
If you do not have a m20i, the lower model numbers will not do two sided copies.
Aug 14, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Double sided printing with Toshiba Studio 3510c series
In the middle of the main screen (in copy mode) there is a big button called "simplex 1 to 1" or it may say "duplex". on the next screen you'll see different ways to do duplex copies. if you have a double sided original then select 2 to 2 / if you have 2 single side originals then select 1 to 2. Place originals in the document feeder and press start
Apr 07, 2009 | Toshiba Office Equipment & Supplies
Single copy out of double original w/o using paper feeder
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
Minolta DI2510 Black and White Copier Logo
222 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
