Question about NorStar M7310 Corded Phone
Speed dial I accidentally erased my speed dial button. How do I put it back? So I can re-enter my speed dial numbers.
    Scholar:
  • NorStar Expert
  • 277 Answers
Feature *4 for personal speed dials.
If you mean Auto Dial button then Feature * 1
Posted on Dec 12, 2012
4 Suggested Answers
SOURCE: Speed Dial
Feature *4
enter a 2 digit code from 71 to 94
specify the external line by pressing the line button
dial the number you want programed
press hold
Posted on Mar 27, 2008
SOURCE: problem with speed dial buttons
to program a speed dial button - <feature> *1 - select button / enter speed dial number / quit....you may have to reprogram each button.
Posted on Mar 23, 2009
cnavarro
  • 2460 Answers
SOURCE: Hello. I have a M7310
What? They are either programmed or not programmed. If the button is blank, I'm voting for NOT programmed.
If your system is old enough, it's probably lost the backup battery. Ugly things, like pulse dial and only 2 lines are what usually happens, along with losing all of the button mapping but your 2 lines and the default programs of LNR, CONF, etc.
If it's just one phone, there's no magic recall. You'll just have to reprogram it. Same with the system if you've lost everything, but I"d call a repair tech first to fix the battery on the software cartridge.
Carl
Posted on Apr 14, 2011
How can I erase numbers from programmed memory buttons without entering new ones?
Press feature *1, then press the key you want to erase, and press the ok soft key without entering in any numbers. This will erase any speed dial or feature you have programmed under that button.
Oct 25, 2010 | NorStar Meridian M7310 Phone
How do I do a group fax with a M20i?
NOTE: The following solution applies only when the WorkCentre has the fax feature.
Speed Dial numbers must be set up before creating a Group Dial. If Speed Dial numbers have not been set up, See the Related Items below for additional information.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Up] or [Down] arrow button until 'Fax Setup' is selected, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until 'Group Dials' is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until 'New' is displayed, and then press the [Enter] button.
  5. Enter a Group Dial number between 1 and 200 using the numeric keypad, and then press the [Enter] button.
    NOTE: If a 'Location No. is Registered' message is displayed, the number has already been stored as a Group Dial. Enter a number that has not been stored, and then press the [Enter] button.
  6. Enter a Speed Dial number to be added to the Group Dial using the numeric keypad, and then press the [Enter] button. The name and fax telephone number stored for the specified Speed Dial number will be displayed.
    NOTE: If a 'Not Assigned Enter Again' message is displayed, the number has not been stored as a Speed Dial number. Enter a number that has been stored, and then press the [Enter] button.
  7. Press the [Enter] button. The Speed Dial number will be added to the Group Dial.
  8. Repeat steps 6 and 7 to add additional Speed Dial numbers to the Group Dial.
  9. After all required Speed Dial numbers have been added to the Group Dial, press the [Menu / Exit] button.
  10. If required, enter a name for the Group Dial using the corresponding buttons on the numeric keypad, and then press the [Enter] button. If a name is not required, press the [Enter] button.
  11. Press the [Stop] button to return to the Standby mode.
Feb 17, 2010 | Xerox WorkCentre M20i All-In-One Laser...
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Need to program numbers in speed dial (or replace lost manual).
If you go to the following webpage there is a link to the manual:
http://www.amazon.com/exec/obidos/ASIN/B00005NGRJ/plaza101-20/ref=nosim/
It is under the 'Product details' section. The section on managing the memory start on page 34.
To change a stored number you just follow the initial instructions, namely:
1. Press the STORE button. ENTER TEL. NO. is displayed.
2. Use the keypad to enter the phone number. If you
want to add spaces instead of dashes in the number,
it will dial correctly.
• To scroll forward or backward, use NEXT or
PREVIOUS.
• To erase the current digit, press ERASE.
3. When finished, press STORE. ENTER NAME is
displayed.
4. Use the keypad to store a name (up to 16 characters).
More than one letter or character is available in each
of the number keys. For example, to enter the letter
“A,” press the 2 key once. For a “B,” press the same
key twice. For a “C,” press it three times.
• To add a space, press NEXT.
PREVIOUS.
5. When finished, press STORE. MEMORY LOCATION is
displayed.
6. Press the memory location number (0-9 or A, B, C) to
store the number.
I hope this helps you.
Jan 03, 2009 | GE 29893GE1 Corded Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Speed dial access
It's easier if you have access to the database to put in names with the numbers, but in the simplest sense, you can take a piece of paper, write down locations, and start entering numbers.
PROG
They are added in sytsem speed dial from the first extension or one designated as the manager's phone. PROG **1234 gets you into programming and 001 is the system speed dial area. With a combination of NEXT's and ENTER, you can be looking at SD 000 (ie PROG **1234 NEXT NEXT ENTER NEXT) and you're ready to enter a speed dial in bin 000. The complete number starts with an access code (9) plus the number as you would dial it. For example 918005551212 ENTER puts that number in bin 000. NEXT will step to 001.
USE
Press INTERCOM or select a line and press AUTODIAL and dial the 3 digit code. If your installer was lazy, you will have a problem as "9" selects the highest line in a trunk group, one that you might not have. In that case, he'll either have to program the system properly, or you will always have to pre-select a line to use speed dial.
Notice that this is just hte instructions for SYSTEM speed dial. I guessed that it was what you're looking for. Personal speed dial is a different set of instructions and it could be either under a button or in your 10 or 100 number personal directory (so that's where the 2 digit SD's went :-))
Anyway, if you need those instructions and can't find them in the user manual, please post back.
Carl
Nov 21, 2008 | Panasonic KX-T7630 Corded Phone
Edit number stored in speed dial
all you need to do is push and hold the speed number button that you what to chang till it starts blinking in the display. i think the name comes up 1st. press enter if that's o.k. ore use the courser to delete. if you have pressed enter then the number show-es up press the arrow key back to erase @ enter the correct numbers. hit enter key. if you git in to something you don't know press the stop key 2 times will git you back to main screen
Apr 11, 2008 | Samsung SF-560 Plain Paper Laser Fax
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
NorStar M7310 Corded Phone Logo
60 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
