Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
Not making ice.
My Magic Chef refridgerator is not making ice but I can still get water from the water dispenser. Any idea as to what the problem may be? Thanks.
    Genius:
  • 1,122 Answers
EITHER YOUR ICEMAKER IS BAD(IS THERE WATER IN THEWELL AREA?)OR YOUR 2 WAY WATER VALVE ON THE BACK BOTTOM OF FRIG. IS BAD(ONLY ONR=E SIDE WORKING,LET ME KNOW WHAT YOU FIND-MIKE
Posted on Jan 13, 2009
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
Magic chef model rc224ad. ice maker makes some cubes but also allows water into bin . water then freezes in bin and won't allow ice dispenser to work
Sounds like you have a seal problem ,see if you can replicate it and watch it and see where it comes out,or can be the shut off solenoid (valve) or freon is low and not cold enough to make enough ice and I'm talking about on the ice unit itself ,not the freezer. Only thing you can do is activate it with the bar and see what happens,that will tell you where the problem lies
Mar 19, 2011 | Refrigerators
My refrigerator first stop making ice, then, a few days later, it stopped dispensing water. Help anybody? Elena
Don't know much about magic chef but you might want to check the water filter,if it has been in there for more than 4 or 5 months it might be clogged depending on your water.If this does not help repost your ?
Mar 01, 2011 | Magic Chef (CSD2610KRW) Top Freezer...
RB214TF ice maker not getting water to make ice?????
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 28, 2009 | Magic Chef Refrigerators
GE refer will not dispense cubed ice
I have the same problem. My GE refridgerator won't dispense ice cubes.
May 01, 2009 | General Electric GSS22JET Side by Side...
Refridgerator is clicking on loudly then buzzing and sizzling
I bet the Iemaker arm has been turned on allowing th eicemaker to cycle every 10-15 mins when the icemaker calls for water it causes the water valve to open. with no water connected to the unit the valve buzzes loudly causing your noise. make sure the icemaker arm is in the up position thus turning the i/m off thanks peyton
Mar 22, 2009 | Refrigerators
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Refridgerator leaking water
You will have to check the defrost drain in the freezer by removing either the back or bottom of the freezer . Thaw ice if found in freezer and check to see if the drain hole is clear. Do not use anything to chip at the ice. Clear ice by warming it with warm water or possibly a hair dryer.
Jun 26, 2008 | Magic Chef CTF2125 Top Freezer...
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
169 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
