42pj350 buzzes but displays no picture.
I turn the TV on and it makes a loud buzz but displays no picture on any channel, even after replacing cables and trying different power sources.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Someone needs who knows what they are doing to open the set and first listen for where the sound is coming from---My guess is the power supply---depending on skill level there are things there a visual inspection may reveal, burnt parts and more commonly puffed up filter caps that if bad can be seen.
42pj350 buzzes but displays no picture. - 12_11_2012_2_02_34_pm.jpg12_11_2012_2_02_54_pm.jpg
Posted on Dec 11, 2012
  • Harrison Clay Dec 12, 2012
    thank you for your assistance, are you suggesting that i open the TV up with someone who has a strong knowledge ?
  • SD Tech
    SD Tech Dec 12, 2012
    thats the point exactly and if they have questions you can follow up by making a comment as you just did right here.
SOURCE: Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Posted on Jan 10, 2008
Highdefjeff
  • 124 Answers
SOURCE: Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Posted on Mar 03, 2009
  • 4 Answers
SOURCE: Polaroid TLU 03711C - HD LCD flatscreen TV 37
I wrote a guide on how to fix this problem. It's really easy to do and only costs £1 (about $1!). You can view, download and print the guide here - http://www.scribd.com/doc/13515584/Polaroid-TLU03711C-Replace-Capacitors-Guide
Posted on Mar 22, 2009
SOURCE: Buzzing sound coming from TV
I just started having the same problem. it comes from a large capacitor changed them but the new ones still make the noise.
Posted on Jul 30, 2009
  • 92 Answers
SOURCE: Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Posted on Sep 12, 2009
Testimonial: "Quick response, i will check it out asap"
My phillips is making a loud buzzing noise, no picture, then it shuts off
presuming it has one two choices: contact Philips (good luck there) or Google the model number with "color wheel"
Oct 31, 2012 | Philips 50PL9126D/37B 50" DLP TV
The TV just started making a loud buzzing noise last week, the buzzing sounds begins after the TV has been turned on for 15 or so minutes- the sound stops about 15 seconds after the TV is turned off. The...
This tv have a colors wheel. The tv colors wheel is dead.The buzzing noise is the cause of the colors wheel is spinning of is axis and rubbing sides of the motor.Hire a tv tech. for the job.Colors wheel is hard to replaced,because have to take out many other machanical parts,even before can change the colors wheel it self.
Aug 31, 2010 | Samsung HL-P6163W 61" TV
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
Loud buzzing at the first volume setting
Check all your wires and make sure that none of the wires that are powering any equipment (including extension cords, power bars, and power cables on the unit itself) are running parallel to any of the audio cables going to your speakers or from your inputs to your unit. This could be what's called AC hum, which is caused when the electrical current causes interference that gets picked up by the audio cables and amplified by your system. Just make sure you move the power cords as far away as possible from the audio cables.
Jan 08, 2009 | Sony STR-DE345 Receiver
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Television sound
if you have a converter box hooked up to the tv as well turn the volume down on both devices and bring the volume on the tv up to mid range, then increase the volume on the converter.....one is overriding the other
Mar 27, 2006 | RCA F27628 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
