Question about Electrolux 450 Watts DLX-N24 Assistent Stand Mixer
Service manual Electrolux DLX - Electrolux 450 Watts DLX-N24 Assistent Stand Mixer
Asks Hi do you have a user manual for a chef classic 901002-140?
Untitled - Trade Connect
https://product.electrolux.com.au/Public/File/?Id=14896The Chef Classic oven is a compact wall oven or under bench oven and is available in the following models. Utauusu- ... The Chef Classic oven has been delivered to you in a sealed carton to protect the appliance from any damage. ... minutes reading the operating instructions in the back. section of this manual. Note to the ...
Apr 27, 2018 | Food Mixers
Where can I download manual for the Magic Mill DLX2000 ?
The manual is $10 from the manufacturer, you can order from the following link.
http://magicmillusa.com/index.php?event=product-detail&productid=51
Let me know if you need anything else.
Benjamin
Nov 04, 2010 | Magic Mill DLX 2000 Stand Mixer
We just got a 6 quart kitchenaid mixer, we have used it once and the loud high pitched sound is very irritating. Is this a problem that will go away in a short time, or do we send it back for repairs? Our...
Hi Wayne. If you want to keep the mixer, you'll have to buy some earplugs. Newer Kitchenaid mixers are all that noisy. The best thing that I can say about them, is that they've got great paint jobs. If you do keep the mixer, other revelations may occur later when the plastic transmission housing fails and possibly ruins your mixer. These units are poorly manufactured in my opinion. I know because I've been through my own Kitchenaid mixer rebuild. I recommend that you return it and consider an Electrolux DLX. My own solution was to buy a used commercial Hobart mixer and rebuild it. I am once again a happy man!
Good luck! ricardok45
Apr 20, 2009 | KitchenAid KP2671 Professional 6 Series...
Instruction manual for magic mill 2000
http://magicmillusa.com/items.php?category=26
Jun 24, 2008 | Magic Mill DLX 2000 Stand Mixer
Dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
May 30, 2008 | Magic Mill DLX 2000 Stand Mixer
Magic mill mixer
majicmill.com
You may be having a problem with the motor brushes and/or bearings.
Mar 04, 2008 | Magic Mill DLX 2000 Stand Mixer
Noise level
its possible that you got a lemon off the factory line or they forgot to put grease into the transmission case.is there a warranty on it?if so take it back.i work for hobart which sold kitchen aid some years ago,if that mixer is less than a year old as stated,take it back or verbally speak to a kitchen aid rep. and tell them your situation.i really belive you should be able to get a replacement as long as you havent overloaded the unit or caused damage.let me know.
Jan 03, 2008 | Magic Mill DLX 2000 Stand Mixer
Magic mill DLX 2000 base sent to repair place
I just found my old invoice where I had sent my DLX to be repaired a few years ago. (I had not put in enough moisture and it walked off the (rickety) table I had set it on...)
I need to send it back again and hence my search for the info.
The gentleman I sent it to was Mordechai Roth at Magic Mill Corp in Monsey, NY (10952) This occurred back in 2000, I can't believe I saved the receipt...
Phone number is 914-368-2532 (If it's still good) I am calling tomorrow to see about sending mine in... Hope you find yours...
JT
Nov 06, 2007 | Magic Mill DLX 2000 Stand Mixer
Problems mixing thinner batters thoroughly
Try a higher speed , this should force the batter out using the centrifugal force generated
Aug 18, 2006 | Electrolux 450 Watts DLX-N24 Assistent...
Electrolux 450 Watts DLX-N24 Assistent Stand Mixer Logo
220 people viewed this question
Top Electrolux Food Mixers Experts
Oscar Netto
Oscar Netto
Are you an Electrolux Food Mixer Expert? Answer questions, earn points and help others
