What are the ac copper pipes sizes? - Heating & Cooling
3 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: tell me the sizes of copper pipes and electrical
If you go with any brand but BTU is same, you can use your existing pipes and wiring. Thanks.
Posted on Jan 20, 2011
  • 4736 Answers
SOURCE: My central air AC unit
You are absolutely right! The copper pipes should have insulation them. When they don't and they get cold in hot weather, they sweat and then freeze. Tubular Foam Insulation is what you need. Most home centers carry it. Once you cut and install it, be sure to wrap it in a good quality Duct Tape.
Hope this helped you. Good luck.
Posted on Jul 15, 2011
1.ton ac capillary pipe size and length I want to know. B coz suction line cooling level is very low gass psi 75
I'm guessing you should have 3/8 & 5/8 copper on that unit with a maximum of 50 feet. I doubt the line set size is affecting your pressures that significantly, you likely have a leak.
May 05, 2017 | Heating & Cooling
What is THE EASIEST WAY TO BYPASS MY HEATER CORE ON MY 2000 BMW 323I
the easiest way is to remove the pipes to it from engine bay and use a copper pipe to bridge the pipes, so you will need to cut the ends off and use some jubiees on the pipes to secure it to the copper pipe standard house hold size copper pipe, if you do need to cut ends off make sure you leave and inch and a half on them so you can fix them back on when the heater core is replaced or fixed. just to recommend i would fix the core as soon as possible
Jan 05, 2017 | BMW Cars & Trucks
Goodman ez-1425 ac copper pipe keeps freezing up
copper pipe freezing on the outside indicates that there is liquid evaporating in the space created by the suction of the compressor
the pipe normally will be insulated to stop atmospheric humidity condensing on the pipe
Suggest that you get in a technician to check gas pressures and ac operation
Aug 06, 2016 | Goodman Heating & Cooling
How can I repair water leak?
Good grief, what kind of water leak? In your car radiator? In the house from a copper pipe? Or a toilet, a sink, a faucet? All these leaks require different fixes. Let us know where the leak is from. Then we'll have a better chance of giving you the correct advice.
I will tell you this, if the leak is from a "pin hole" in a copper pipe in your house you need to get a water testing kit to see if you have acidic water eating away your copper pipes. If so you need to replace the copper pipe and then get an acid neutralizer ASAP. If you do not get an acid neutralizer all of your copper pipes will be leaking since the acidic water has been eating away at all your pipes.
Jan 11, 2016 | 2004 Saab 9-3
When should I pipe thread on copper, metal or plastic?
Seems a question with many possible answers.
1) Are you asking if you should thread the pipe?
2) What size pipe?
3) Threads on copper, not normal, not possible in most cases.
4) Thread Plastic? Only if it is Schedule 80 or above.
5) Thread metal. Assuming galvanized or black iron, this would be normal.
I need a lot more detail to intelligently answer the question.
Gary C
Oct 14, 2014 | Water Heaters
Copper brake pipe size
go into any reptuible car spares place with car detailes they will be made for you within an hour dont use main dealers you will pay way too much.
Jan 10, 2013 | 2003 Hyundai Elantra GLS
My central air AC unit (Double wide home) always works for generally up to two hours, then it freezes up, by the copper pipes ice over, shutting them off and letting them thaw out, works to get it going...
Jul 15, 2011 | Coleman Heating & Cooling
We would like to connect an imperial us copper pipe to an Australian copper pipe. These are water pipes in peoples homes. We are using the imperial standard, which is a bit different from the Australian. I...
they make a piece that fits numerous sizes of pipe, it just slides on, at the Home Depot I think they are called the Gator Bites, lowes has similar but doub't know the name, you have to know what size you are close to ie 1/2 , 3/4 etc
Dec 18, 2009 | Plumbing
Pipe sizes
depends on the distance between the source and the unit
Feb 27, 2009 | RTO Hubbard Supply Co 250 Up to 1" CTS...
Heating & Cooling Logo
168 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
