Question about Kenwood KDC-W7027 CD Player
Kenwood KDC-W7027 will not go home all the way
Hi, When i turn my Kenwood KDC-W7027 off the angle goes to 90 but it wont go home correctly and I can adjust the angle correctly it just goes up and down then returns to the same place. The slide works fine as does all of the other bits it just wont home correctly HELP
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Chances are, there is either a bad gear or a bad position sensor lever. More than likely it will be the lever. Both parts are inside of the deck itself
Posted on Dec 11, 2012
SOURCE: Kenwood KDC-MP2035 security code
yo tengo un reproductor kenwood kdc-mp2035cr pero este no me reproduce nada solo me sale un mensaje que dice protect y no me deja hacer nada ni colocarle nada por el auxiliar
Posted on Jul 06, 2008
SOURCE: turn aux on on kenwood kdc-mp205
In order to access the AUX option the stereo needs to be in Standby mode. To do this just hit the SRC or source button until you reach the Standby option. Now hit the menu button and scroll up or down until you reach the AUX on/off option and just turn it on. Hope you find this helpful.
Posted on Oct 28, 2008
SOURCE: Kenwood KDC-3028 unlock code
TY TY TY..fixed this right on up. Only suggestion I could make is that a diagram of where the aforementioned buttons are. I did mine at night so the small words were hard to see. I just replaced my battery and cleaned off the cables connectors when this problem occurred. TY so much for this.
Posted on Nov 02, 2008
  • 733 Answers
SOURCE: subwoofer option on my kenwood kdc 138 receiver
go to kenwood wesite to down load instruction manuals
Posted on Sep 14, 2009
  • 3 Answers
SOURCE: Kenwood KDC-MP208 Clock Set
Make sure that the source is set to "Standby" when trying to access the menu. It took me about an hour to figure it out and afterward I felt like a ******.
E05 error kenwood kdc-w7027
Sounds like your laser is dirty or faulty. Try a cleaning CD.
Dec 10, 2013 | Computers & Internet
KDC-7027 car sterio comes on for a second then moves then goes off again
sound like you have a bad ground. pull the stereo out and check your ground wire go from there.
Jan 11, 2011 | Kenwood KDC-W7027 CD Player
How can i fix it
you need a part cog just replacing one at the moment but remember the position it was in or it wont work when reassembled. cog is only nilon probably threaded. take off top, one screw. take out cd plater two silver screws either side on front. carefull when disconnecting ribbon under neith push up brown clip either side then prise out ribbon. now with great care unscrew two brassy collered screws on black metal cover to right hand side also a black screw on the side. you will have to move the screen in and out when doing this use the white cog to you right on top roll it backwards and forwards.now you will see the mechanisim for the front panel you will see from there whats threaded. probbably the little clear white cog sideways on on the right.
hope this helps.
mike.
Aug 02, 2009 | Kenwood KDC-W7027 CD Player
How to put the code in my cd radio
SELECT THE SECURITY DIGITS TO ENTER PRESS THE FM OR AM BUTTONS PRESS THE [[ ]] ARROW SEARCH BUTTONS TO MOVE ALONG AS YOU ENTER YOUR CODE WHEN CODE IS ENTERED PRESS AND HOLD ]] FORWARD SEARCH BUTTON FOR 3 SECONDS RE-ENTER MAY APPEAR REPEAT THE SAME AS ABOVE TO COMFIRM CODE IF NESSARY HOPE THIS HELPS YOU JAKE YOU CAN DOWN LOAD A MANUAL FREE I HAVE ENCLOSED MY MOBILE NO 07936635539
Jun 07, 2008 | Kenwood Car Audio & Video
Head unit problem
Hi John Steel
Try disconnecting it from all 12 volt sources(overnight)to reset the code entry procedure. If that dont sort it, let me know and we shall try something else
regards
robotek
May 21, 2008 | Kenwood KDC-MP228 CD Player
Radio Removal
hi cant find reoval for this odel, but am 90% sure that : http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KDC-MP6090R.pdf
is the same to remove see page 42
Regards
Mark
Blue ICE
Mar 21, 2008 | Kenwood 2005 KDC-MP5028 CD/MP3...
Kenwood kdc 7027
The home position switch from the angle of the front display is not pushed correctly. the problem is mechanical.
If you glue a little tip of plastic between the actuator and the homeposition switch, your problem is history.
In my case, a tip of a little tiewrap did it.
Feb 20, 2008 | Kenwood KDC-W7027 CD Player
KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact kstahl65@att.net for additional info
Jan 21, 2008 | Kenwood eXcelon KDC-X879 CD Player
"WAITING 3"DISPLAYED
KENWOOD SECURITY CODE CLEAR procedure Your radio will require one of the following procedures. Type 1 During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that ??? disappears). Then using your remote enter your code. Type 2 Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear". Then using your remote enter your code. Type 3 Model# DPX-4020 and DPX-4030 Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display. Then using your remote, enter your code. Enter your number from the remote control unit. Your code number is 5227 (KCAR) * Press numeric key ?5? ( 2 times ) and press the Track UP/Next Track key * Press numeric key ?2? ( 3 times ) and press the Track UP/Next Track key * Press numeric key ?2? ( 1 time ) and press the Track UP/Next Track key * Press numeric key ?7? ( 2 times ) and press the Track UP/Next Track key The security is canceled and the set enters the TUNER mode! Luck
Nov 20, 2006 | Kenwood KDC-W7027 CD Player
Kenwood KDC-W7027 CD Player Logo
63 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
