I have a Denon ADV-M51. When I switch on the power button( On/Standby button), instead of going from Red to Green, it goes from Red to Green and immediately into blinking Orange. Nothing I press seems to turn it to the Green On light. Could you advise on what I need to do to get it to switch on to Green and work again? Thanks.
techman
  • 3130 Answers
SOURCE: No Power
I mwas gonna suggest that you need the speakers attached but you stated later that it did the same thing with the speakers attached. The unit switching off after it checks its self is NOT a normal thing. TAKE IT BACK BEFORE ITS TOO LATE!! GOOD lUCK
Posted on Jun 18, 2006
Foxyjay
  • 13 Answers
SOURCE: Power Button Flashing Red
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-1508
Hope thats of use!
SOURCE: Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Posted on Oct 16, 2008
  • 3 Answers
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Posted on Jan 05, 2009
Denon CD not switching on
The lightening causes a strong electro magnetic field to build up very quick and also break down. This pulse can induce a huge current in electronic equipment, causing damage in semiconductors.
The damage can be in any of the components in your Denon. It also could be only one semiconductor. FET's and MOS FET's are the most vulnerable.
Without a service manual, tools and the Denon on my desk it would be impossible to tell what is damaged.
But I would trust not any component in the player.
Also read ESD and what happens direct and what can happen when times goes bye.
Jul 22, 2014 | Denon Audio Players & Recorders
Denon not switching on
Talk to Richer Sounds hi fi there will be a shop near you if you are in the UK.
M51 charger has solid red light and a blinking green light
Battery is shorted or may have cristlized replace battery. This will solve your problems.
Sep 16, 2012 | Invacare Supply Group Invacare Pronto M51...
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Turns off after 4 secs or so....From Green to Red,
Receiver turns on Green but on pressing button again for red light standby, red light will not come on for this Denon receiver. Recently light came on saying Panel Lock is on. I was not able to get tuner to work.
Aug 25, 2008 | Denon AVR-1905 Receiver
Jun 27, 2008 | Denon AVR-1705 Receiver
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
No Power
Jun 18, 2006 | Denon AVR-1706 Receiver
110 people viewed this question
 Grubhead
Grubhead
