Question about Minolta DI2510 Black and White Copier
Single copy out of double original w/o using paper feeder
Bizhub di2510, I can not figure out how to make single copy out of double sided original without using paperfeeder. I work at a physicians office and we make copies of insurance card front and back. It would be great is it would all be on one page.
  • 469 Answers
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
Posted on Apr 14, 2009
Make double sided copies bizhub 350
use the control panel select 2 side from single sheets or double side original
Jan 31, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
How to make duplex copies from toshiba e-studio202L
I am going to assume you have a document feeder (ADF) on the copier.
Insert originals into document feeder and press the 1-1 simplex button on the LCD screen. If have single page documents that you want to turn into double sided documents then select 1 - 2 button. If you have double sided originals already and want to make double sided copies then select 2 - 2 button. Then hit the green copy start key...done.
Jan 17, 2010 | Toshiba e-Studio 202L Copier
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Both our brand new copy machines SHARP M316 have problem with the
first thsing to check is the side guides for the paper make sure they are set against the paper being fed through if not the paper will be pulled through at an angle and this can cause your problem you can alson get a slightly heavier paper and put that through to see if you have a jam..did you remove all the packing tags and paper protectors
Jun 15, 2009 | Office Equipment & Supplies
Double sided printing with Toshiba Studio 3510c series
In the middle of the main screen (in copy mode) there is a big button called "simplex 1 to 1" or it may say "duplex". on the next screen you'll see different ways to do duplex copies. if you have a double sided original then select 2 to 2 / if you have 2 single side originals then select 1 to 2. Place originals in the document feeder and press start
Apr 07, 2009 | Toshiba Office Equipment & Supplies
Double side to single copy w/o paper feeder
Try this.
Set the copy for duplex.
Put the drivers license on the glass.
press the start button.
Turn drivers license over.
Press the start button.
Should copy on both sides of sheet.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
Konica Minolta Bizhub 7235 copies curling at exit. Single or double sided from Document feeder curl almost to the size of a paper towel tube/core
dear friend:1-check the paper and use fresh paper out of wet and stored in dry place.2-use cooling oil and replce oil cartidge in the heater section.3-replace silicone roller (the lower roller in the heater}4-check for smoth movement of exit section(gears-chain-rubber belt}in a good condition replace any defective part.
Feb 20, 2008 | Office Equipment & Supplies
Minolta DI2510 Black and White Copier Logo
143 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
