My mag light got bump, rolled off the coffee table and hit the floor (carpeted) and ever since it won't turn on. I changed the bulb and batteries, but didn't work. Any ideas?
put the first one in positive side toward the light,, and the rest go in the same way, make sure the spring is attached to the base and screw it on, the positive side of the battery is the side with the bump on the end,, if it doesn't work after that ,, in the end cap of the flashlight you should have a extra bulb,, replace that and try it ,, be sure to put the spring back on the end cap
To put it simply, no. By floor mode I'm assuming you're stopping the brush roll from turning so that you can clean hard surface floors instead of carpet. When the brush roll doesn't turn you do lose agitation which vibrates the carpet so that the dirt is more easily picked up by the vacuum. But you don't lose suction because the brush is not turning.
There are diffferent mag lite bulbs made for different amounts of batteries. Be sure that you have the 5 cell light bulb. Also try to keep your fingers off the glass. if you get any oils on it, wipe it off before turning it on. Also you can get mag lite specific bulbs...they cost more but they're worth it.
Your laptop battery should just slide out. You may be thinking of the CMOS battery (silver, round battery). The external battery is easy to remove and it needs to be removed first.
First check the turning light's relay.Use cables straight from the battery to test each turning light separately to make sure that nothing's wrong with them.
