Question about Watches
Female watch ORIENT (mechanism HE721) properly and precisely go only if its lay on a table. On a hand - lag behind at 1-2 o'clock for a day. Where it is possible to order the mechanism and how man
5 Suggested Answers
SOURCE: Setting the hands on this watch
press your "mode" button 5 times until it says on lower display "H-SET". Then press the "adjust" button until it beeps.
Now hold the "forward" button and the minute hand is moving.
Enjoy :o))))
Posted on Feb 03, 2008
SOURCE: Timex expedition problem
You probibly need to have the anologe serviced. It isn't like the old days when watches had a mainspring which, when you wound it the gears would push by anything that got in the gears way because of the pressure form the mainspring. Now with quartz watche ANY little thing ( dust sooo small) will stop the gears from running. I would take the watch to a reputable watchrepair and have them check the battery. DO NOT ask them to sell you a new battery just CHECK it. If you get a new battery, it the watch probibly will run good again for about 3 weeks , and then start acting up again, because a new battery might have enough power (at first) to get by the watches problem untill it uses some energy up. But if your battery is bad that to could cause this , but that is highly doubtful that is the problem.
If you still have a problems please let me know I will be glad to assist you!
Posted on Aug 18, 2008
HW_Dude
  • 87 Answers
SOURCE: analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Posted on Jan 10, 2009
Mykel_N
  • 315 Answers
SOURCE: how to recharge B023 ecodrive watch?
hi, how long do you keep it under the light for?
Have a look at page 2 on this pdf file from the citizen website for more info on charging times.
http://www.citizenwatch.com/Technical/English/Full/B023_ebook.pdf
I hope this helps a little,
Regards
Mike
Posted on May 26, 2010
How to fix dramatic lag of the hands of my Casio 3747 watch?
Sounds like a battery problem to me. Some places like a swap meet have watch repairs real cheap and they do an excellent job. Good luck.
Apr 07, 2015 | Casio Watches
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 | Watches
I need to remove the back of my wall clock to tighten the hands, someone glued the face on
no chance to remove the box
it is held in place by a nut on the spindle shaft from the face of the clock under the hands
Jun 20, 2017 | Kenneth Cole 1213 Wrist Watch
My seiko 5 automatic runs to quick
Balance spring in your watch is sticking together and causing the watch to run fast. It can happen when watch gets magnetized or there is some oily residue left on balance spring. To fix this you will have to show your watch to the watchmaker, because this is very specialized job to do and the balance spring is so delicate part, it can be damaged by simple touch.
Feb 28, 2011 | Seiko Watch SNXJ89K1
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
Have a Galleria Grandfather clock thats chimes are off. How do I get them correct? Bought it at an auction and did not get any information with it. It chimed correctly in the beginning.
I suspect that the mechanism needs cleaning.
Take a look inside and if there is the slightest sign of dirt (particularly on the striking mechanism) then it should behave properly after cleaning.
May 01, 2010 | Watches
Setting the correct time on Seth Thomas clock.
Correct technique definitely is CLOCKWISE ONLY. You are unbelievably lucky person if did not damage striking mechanism within 25 years while adjusting hands anti clockwise. If I'd have such a luck, I'd try to play lottery. :))
Feb 04, 2010 | Timex Watches
Don't know how to properly wind Elgin 400 day anniversary clock
Wind the clock until there is a sudden increase in resistance (it is then fully wound). So not apply a great force, as older clocks may be weaker and overloading the spring may break the termination and result in a new spring being required.
If you think it is becoming too stiff, just stop winding and see how long it runs for. I have often heard the term "over winding at clock" but have never quite understood the term. As a retired engineer I think that springs that break because of overenthusiastic winding are probably near the end of their life anyway.
Jan 13, 2010 | Watches
Aug 18, 2008 | Timex Expedition 84601 Wristwatch
Watches Logo
79 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
