Question about Valor Toys
Valor homeflame G C No 32-810-38 installation instuctions
3 Suggested Answers
SOURCE: Have Valor Homeflame Unigas fire that will not
Have you tried changing the 9V battery under L side panel?
That's what was wrong with mine.
Cheers
Posted on Apr 25, 2010
  • 4 Answers
SOURCE: attempting to light valor homeflame
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Posted on Feb 18, 2011
When clicked on men of valor single player option ,it shows loading but it quits why
Try to install this patch http://www.fileplanet.com/148108/140000/fileinfo/Men-of-Valor-v1.2---v1.3-Patch-%5BEnglish%5D see if it fixes the problem.
Oct 15, 2013 | Vivendi Universal Men of Valor for Windows
Initial problem was that fire was taking long time to light, no spark being generated intermittently. Now Gas fire seems to be going off on its own when it has been on for a while. Fire is the hole in the...
First, have you changed the battery in the ignition system? If you haven't this could be causing your ignition problem. In addition, the Thermocouple may need to be replaced to solve the problem of the burner flames going of on their own. That's assuming the pilot light is also going out when the burners go out. It would also be wise to check the vent pipe to make sure it's not obstructed in any way. As this also, could cause the flames to go out. Because there is a Safety Overload Switch, that automatically shuts the burner off is there is a gas and heat buildup/backup in the firebox.
As far as replacing the Thermocouple is concerned, this unit uses the same type of stand-alone Thermocouple, as the older DESA Vent-free gas log sets and fireplaces used. It's held in place with a saddle strap mounting and is fairly easy to replace.
These fireplaces are made in the UK and therefore, are more complicated to install, diagnose a problem and then solve it, than those made in the U.S.
Hope this has helped get you headed in the right direction.
Feb 25, 2011 | Heating & Cooling
I have an old valor homeflame fire could you tell me how tha logs are put in position please
Here's a link to the Valor website home page.http://www.valorfireplaces.com/
Click on the Downloads tab and you may find the Owners Manual for your gas fireplace. It will show you how to install and arrange the logs properly. If you can't find the model you have, on the manuals page, use their contact information and call them.
Hope this helps you.
Feb 18, 2011 | Heating & Cooling
Can I fit a Valor Homeflame Harmony gas fire with a class 2 flue?
Just for information ... whether you're doing it as a 'B' -Vent (Straight up) or a Direct Vent (Straight out the back), it requires an appropriately sized Coaxial Vent Pipe. A Coaxial Vent Pipe is a pipe within a pipe, That has an air space in between the inner and outer pipe. Of course it will also need the appropriate termination cover.
For for technical advice on proper venting go to http://www.valorfireplaces.com
Feb 08, 2011 | Heating & Cooling
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Valor Gas Fires
Jan 14, 2011 | Valor Toys
Put together starter system need a diagram on a valor tropic 121 wall gas fire
You should be able to download the installer instructions on
Valors website, the information can be found here
under Trade then installer guides
www.valor.co.uk
alternatively new Valor Gas Fires
Jan 02, 2011 | Valor Toys
Bought valor homeflame super off a friend gas fitter won't fit until he gets istruction maual
google valor you should be able to get manual off there site you will need model number
May 02, 2010 | Heating & Cooling
Instalation manual for valor flamenco unigas 111 balanced flue wall mount gas fire
hi there, did you mange to find a copy of the instructions for the valor flamenco unigas ii at all?? i need to replace the ignitor so would like to see a copy..
cheers
sharron
Mar 08, 2009 | Heating & Cooling
Toys Logo
178 people viewed this question
Top Valor Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Valor Toy Expert? Answer questions, earn points and help others
