Question about Water Heaters
My eemax tankless water heater turns on for a few seconds then turns off.
    Problem Solver:
  • 19 Answers
Couple things....is it a brand new unit with this issue or existing unit that just developed this problem?
Posted on Feb 10, 2013
SOURCE: Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Posted on May 12, 2009
SOURCE: Tankless water heater (Paloma) Has C2 11 error
I had this problem with the C2 11 error code. My unit is 1.5 years old. I called Paloma and they emailed me an 11 page document to clean the burners. I am not an HVAC but I got the feeling that's who the instructions were for. Very difficult but you can do it if you're handy. You basically take apart 1/2 the unit, be carfull not to lose any screws and label all the little brackets that come off. It took me 2-3 hours to get to the burners. I used a can of air (for keyboards-electronics) to blow on the burners and clear any build up. After putting it back together (carefull to make sure the 3 gas tubes make a seal when re-installed) the unit works. I did this today so I'm not sure the unit will still work in a week/month. I am dreading having to do this every year to keep the unit running.
Posted on Oct 21, 2009
Testimonial: "THIS WAS THE PROBLEM THANKS"
SOURCE: My Paloma tankless water heater flashes C2 11 error code
I just had the same problem and I fixed it in about an hour or 2. First shut off the gas,water and power(unplug it) Take off the cover There are about 20 screws above the electrical circuit board. You have to remove all of those screws to remove plate that is covering the burner assembly. The burner assembly has these 3 pins that look like number 7's these are covered with build up and gas can't flow right. That's why you get the c211 error not enough gas. Take a wire brush and gently remove any build up, I also cleaned the thermocoupler which is next to the burners. It looks like a metal pin with a couple of wires coming out of it this was also very dirty. I took a can of air and basically freshened it up It works perfect now. Email me with any Q's at Mario@myredr.com Good Luck All that you need is a long phillips screw drive and a drill because its about 25 screws
The burner assembly has 2 screws all the in back underneath the assembly once you remove those 2 the assembly comes out . You don't have to disconnect any wires.
Posted on Oct 29, 2009
  • 244 Answers
SOURCE: Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Posted on Nov 01, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Hot water not coming out
Tank-type Electric water heater?
Press reset button.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add comment and describe water heater, and more detail about problem
Mar 30, 2013 | Eemax "Flow Controlled" Electric Tankless...
How can i to change the element of the eemax ex95?
http://www.eemaxinc.com/assets/files/Series%202-trouble.pdf
May 15, 2011 | Eemax EX95 "Flow Controlled" Electric...
Wher does white wire go on ex 190 eemax water heater
It runs off 220v, meaning there are two "hots" and a ground. The 190tc uses TWO sets of 220v at 40amps each. Instead of only having one dbl throw breaker, you need 2. Having said that... the white wire "should" be the same as the black wire and can be connected which ever way you like
Jan 17, 2011 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
My house has 200 AMP Service, will this work ok with the EEMAX EX380T2T2? It requires 4 40AMP Breakers.
your water heater will take a 160 amps of you service. I would not install one if it was me. The total demand in the dead of winter with furnace, water heater and lights on will cause you to brown out.
Oct 05, 2010 | Eemax EX380T2T2 Series 4 Whole House...
The center heating element is no working. How much does a replacement element cost?
the price will vary in different localities.
you should call a plumbing wholsaler in your area. Home depot and Lowes will not carry these, neither will you local hardware store.
the replacement is faily simple. Eemax is a nice heater, although faily expensive to opperate.
Aug 20, 2010 | Eemax EX280T2T Series 3 Whole House...
Fluctuating water temp. It is hot when I start the shower,
Iam guessing your using it faster than it makes hot water. May need a larger unit or a second one,in the system
Apr 10, 2010 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
No hot water
in and out hooked up right?
May 17, 2009 | Eemax EX280T2T Series 3 Whole House...
We are currently updating or eemax heaters with the newer control
have you tried eemax.com go to customer service lititure request... they also have a tech support number... if you need more help feel free to contact us as sales@heaterup.com
Apr 11, 2009 | Eemax SP4277 Single Point Electric...
Water Heaters Logo
47 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
