Question about Boating
Boiler problem. Heating and Water cold. Help - Boating
    Problem Solver:
  • 8 Answers
Read the instructions. Pressurise the system. Set clock. Set timer.
Fire it up.
Posted on Dec 11, 2012
Boiler,heating and water all working OK but manual override to turn heat on before preset time caused dripping under boiler.Cause and solution?
Did the boiler winter over with the heat turned off and no winterization? If so, then the boiler may have frozen and cracked. Replace it.
If it WAS drained down and winterized, and you just filled it with cold water before firing it, it may be condensation.
May 05, 2017 | Water Water Heaters
Worcester 350 combi boiler on but water cold and radiators cold. Have put pressure up but made no difference. What's wrong with it?
If the inline pump is not working no hot water will flow into your radiators. The pump pushes the water in the lines to create a water flow. Increasing the pressure will not help in this case. I recommend you put the pressure back down as it usually is preset when the boiler is installed. My pump is about three feet back of the boiler on the intake line. If you don't know what you are doing I recommend getting a repair man as you could create more problems by over heating the boiler its self and blowing the electrical parts up.
Feb 06, 2015 | Water Water Heaters
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Jun 14, 2017 | Water Heaters
Ls80t hot water goes hot cold hot cold heating is ok
http://waterheatertimer.org/How-to-fix-water-heater.html
What kind of water heater do you have? Boiler, indirect?
What brand and model?
Or is this a HVAC unit?
Gene
Aug 17, 2014 | Water Heaters
Boiler working but radiators cold
Seems that you may have bad circulation pump.
Feb 24, 2013 | Water Heaters
I need to power flash a vaillant boiler. can you please help. water goes hold and cold, sometime the heating stop but the water works and vice versa. i was told by an engineering that it needs power...
Hi
Although not a PC problem, i have had this same issue on my Vaillant Boiler, the problem you are describing is not a power flush problem, you need to clean out your exisiting diverter valve or purchase a new one
The diverter valve is repsonsible for either providing hot water or providing hot water to the central heating, when this valve gets stuck in between the symptoms you have described above occur
I would also not recommned that you do a power flush yourslef as you may end up damaging the boiler and its pump
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 23, 2010 | KDS Valiant 6380iPTD-01 Notebook
Which is the cold water input to the worester 240 combi boiler . because of the position its difficult to check . Im fitting a hydroflow limescale reducer .from left to right there are 5 pipes is the cold...
HI turn the boiler on to heating and see which pipe gets hot that will be your heating flow the return will be cold at first , then put on hot water only, pipe to hot taps will get hot , water inlet will get cold , you should be able to work it out from that the middle could well be the gas ?
Jan 30, 2010 | Heating & Cooling
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
No hot water help
have a ariston euro combi boiler ,the problem to get hot water i have to turn the heating on to get hot water. but now it only run for a few min then run cold please help
Feb 18, 2008 | Washing Machines
Boating Logo
21 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
