Bought a brand new LG 47" LED HDTV and now the sound doesn't work. It works if the Xbox 360 is hooked but no alone with only cable. With that said, it was working when I went to work so my wife may ha
    Problem Solver:
  • 7 Answers
You may need to unplug the xbox from the tv as the electronic hdmi switch may be stuck ???
Posted on Dec 11, 2012
  • 244 Answers
SOURCE: AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
Posted on Nov 26, 2007
salt56
  • 373 Answers
SOURCE: No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
Posted on Dec 30, 2007
  • 3 Answers
SOURCE: LG 47" 47LG50
Most likely it is not the TV; it's a grounding problem. Are all your devices plugged into the same power strip? They should be. Can you plug that power strip in to another outlet in the wall (even with an extension cord, just for testing purposes)? If that removes the lines, leave it plugged in there. If you can't leave it plugged in there, you'll need an isolator like the Jensen VRD-1FF or similar.
Hope this helps!
Posted on Jun 12, 2008
SOURCE: installing wii to panasonic viera 50'' plasma
I could resolve the issue. First of all, the wire supplied with the wii is not compatible with your TV. This 3 point connector, will end up giving you b/w screen. So you need to buy the 5 pin connector. I bought from Frys for $19.99. The box says "High Performance Component HD A / V Cable" (like this one: http://www.bizrate.com/wii-accessories/oid875654433.html )
In any case, do below
1> find the 5 point input row (vertical) on the back of your TV.
2> Insert the connector, in the sequence of Red pin being the bottom most. If its 5 pin connector, then start from the lowest point on the back of TV. If its 3 pin connector, use the top 3 points, on back of your TV. Red always being the bottom most in sequence.
Once again, buy the 5 pin connector, as inserting these pins on the back of your TV when the TV is already mounted on wall, is the hardest part to do...so why to waste your enerty in doing again and again. I am sure you would not like the black & white screen coming with 3 pin connector.
Posted on Dec 27, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Posted on Dec 31, 2008
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Feb 06, 2013 | Video Game Consoles & Games
Screen went completely white but still have sound
Try with the Mitsubishi remote the soft restart, set on Menu,1,2,3, and enter.
Dec 07, 2012 | Mitsubishi WD-65734 65" HDTV
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
Xbox 360 hookup problem
Check the video cable coming out of the xbox, depending on which model xbox it is (arcade, pro, elite etc.) it will most likely have both component cables - green, blue and red or RCA cables - Yellow, red and white. It sounds as if your JVC would only be able to run RCA cables (due to its age) so use the yellow cable for video and white and red (or just white if you only have a yellow and white input) and then make sure the switch located on the cable is switched to "standard" and not "hi definition" hope it helps. aus_joel@hotmail.com -if you have any further problems
Jul 06, 2009 | JVC LT-47X788 47 in. LCD HDTV
New HDTV.. xbox 360 has no audio but has video
alright. make sure that your red, green and blue are all plugged in properly and that your audio plugs are also in there correct plugs. i think audio is red and yellow. correct me if im mistaken
Jun 10, 2009 | Microsoft Xbox 360 Console
New xbox 360 arcade no screen or sound
to start off,what type of cable are you using??
since you've already tried using 2diff TVs,basically its with the console
try using a different AV CABLES, if it still doesnt work,try calling xbox support hotline for possible replacement of your cable or for processing a repair for the xbox if necessary..
since you just bought your console,try going back to the store where you bought it and have it replaced, because for the repalcement of the cable if you call xbox support,it will take 8-12business days for toureceive it and 2-3weeks for the turn around time of the repair for the xbox.
May 17, 2009 | Microsoft Xbox 360 Console
XBOX not connecting to LG flatscreen -no visuals only sound
There is a switch on the cable where it plugs into the XBOX that says HDTV/TV please make sure that it is set to HDTV when using component connectors.
May 13, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
Sound with no picture
Have you looked at the side of the cable and made sure that the switch is set correctly? you have to select either HDTV of AV I believe. If that isn't the problem, try hooking it up through a different input on your television. I don't think it's your xbox because with any hardware failure, you would get the RRoD (red ring of death). I would definitely troubleshoot the TV. Try to hook up a regular DVD player in the input that your xbox is in and see if it works.
Jan 29, 2008 | Microsoft Xbox 360 Console
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
