Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Have replaced Catridges but ink light stays on and printer not working!
  • julia whatley Dec 11, 2012
    I have re installed printer but this has not solved the issue.. Light still on printer in active!
BAGAIMANA SOLUSI CATRIDG TIDAK BERGERAK SAMA SEKALI, TETAPI DALAM KEADAAN LAMPU HIJAU DAN MERAH NYALA????
TOLONG DIBANTU
Posted on Dec 19, 2012
All the lights are blinking and when I tried turning the computer off and then back on, the part that holds all the ink cartridges went back and forth and then went all the way to the left and made an...
unplug printer,access the catridges,remove all the catridges,replug machine in till carrier comes back into normal position,refit catridges propely,try printing
Nov 01, 2013 | Epson Stylus 2200 InkJet Photo Printer
The answer to my error 5100 question was replace pinhead and clean. where is the "pinhead"??
You need to open the top cover, access the ink catridge case(Where catridges hung), then look for other objects that look like ink catridges but smaller, that's where the catridges feed ink (into the print heads) usually separate by colors cyan, magenta and yellow Usually Black is a lone. Replace the print Heads and clean where the dirty ink drops.
Dec 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Cartridge error code 1203
HI Don,
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
Solution
Use the klennex with a few drops of water to dampen and clean off those contact on the holder and printer may work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
-rate this if it helped you.
Apr 08, 2010 | Dell 962 Photo All-In-One InkJet Printer
Ink cartridges stuck after replacement
HP PSC 1350.
Very sensitive printer. Due to dust, the catrdges are getting stuck at right side. Please clean the steel roller where the catridges are rested. Clean it with nice cloth and if possible put 3-in-1 oil in that area only for the smooth flow of catridges in that steel stem or roller.
This might happen iif we are not installing the orignal and genuine catridges and there is a chance of ink gettng leaked onto the printer.
Kind advise is if the printer is old, please put an annual maintenace service contract with local authorized hp Printer Dealer which will solve your problem once for all.
have a nice and good working day.
Jul 16, 2009 | HP PSC 1350 All-In-One Thermal Printer
Lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
179 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
