Question about Kenmore 24032\24036 Top Load Washer
Washer will not fill in auto can force it to fill why
Kenmore washer
washer does not recognize water level will not fill in audo can fill when forced
    Genius:
  • 1,122 Answers
MAKE SURE YOUR WATER LEVEL HOSE HAS NOT COME LOOSE(ON TUB,AND INSIDE TOP HEAD)IF THATS GOOD THEN YOUR WATER LEVEL SWITCH IS BAD,LET ME KNOW-MIKE
Posted on Jan 13, 2009
How do I force washer in drain cycle?
Hey Nick, to force your washer to drain is really easy. You will need a bucket and some extra towels. Simply remove the drain hose from the house drain pipe and lower into the bucket. If your bucket fills up, simply raise the hose above the level of the washing machine and the water flow will cease. Please reconnect with us if you do need any further assistance. Best Regards, JK
Oct 25, 2015 | Electrolux EIFLS60JIW Washer
Why will it not fill with water but will drain water?
The problem could be 1 of several.
1. Ensure the fill hoses are attached correctly ( hot and cold hooked to correct fill valve positions) and turned on.
2. Are you sure it's not actually filling with water but you're not seeing it because the water level is so low. If it drains the water has to be coming from somewhere!
3. There are screens inside the fill hoses attached to the fill valve behind the washer that can be plugged. When city workers flush lines sand can be forced into the home supply lines to plug these screens.
4. Bad pressure switch or the switch can have suds residue to cause intermittent problems.
Sep 01, 2014 | Kenmore Washing Machines
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Detergent dispenser does not empty after washing
it could be either a leaking water inlet valve or the pump is not emptying all the water from the machine and when it goes in to spin centrafugal force forces water back up the filler pipe
Jan 17, 2010 | Kenmore 44102 Front Load Washer
Does not fill
Check the solenoids at the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid.
Hope this helped and best wishes.
Aug 14, 2009 | Kenmore 24032\24036 Top Load Washer
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Top arm does not turn. leaves white stuff all over dishes.
Without having much information to go on, I would venture to guess there is a problem with the water supply. If the initial water fill level is low, the force of the water coming out of the spray arms is minimal and would never be forceful enough to dissolve the detergent used. When starting a a new cycle and it runs for a few minutes...filling then stopping, open the door and take a good look at the level of the water. If below the heating element, add about 1-2 gallons of water and close the door. Does the sound of the water seem to be more forceful? If so, remove your water supply line going to the dishwsher and look inside the valve itself. See if the screen is blocked. If it is, using a small screwdriver, scrape the screen and then blow it out. Reattach and see if the unit fills with more water this time. If I can help further, I am here....
Waiting to hear from you,
Eric Campion
Feb 18, 2009 | Dishwashers
Very poor cleaning all of a sudden
suspect blockage in the actual spray arms - take them out and clean under the tap. a check is to open the door when in operation and see if the spray arms are rotating. they are made to rotate only by the force of water thro angled jets at the end of the arms
Mar 26, 2007 | Kenmore 24 in. 16263 Dishwasher
Wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24032\24036 Top Load Washer Logo
118 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
