Question about Philips Gogear Vibe 8gb Mp3 Mp4 Video Player 1.8" Silver Sa2vbe08s/17
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
    New Friend:
  • 16 Answers
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Posted on Feb 25, 2013
SOURCE:
Connect mp4 player to usb
USB ports on car stereos are not designed to be universal, regardless of what the USB acronym implies. They are typically designed for a specific product, either iPhone, Android, Blackberry, or a combination of those. They usually work with a blank flash drive (no operating system on it). That would be my recommendation: Buy a flash drive. $5-$10 invested will probably get you more storage than the GoGear and will work with USB.
The reason USB sounds better than the auxiliary input is because with auxiliary, the D-to-A (Digital to Analog) conversion is done by the GoGear, while with USB it is being done by the car stereo.
Dec 20, 2013 | JVC Car Audio & Video
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with your MP4 player.
Restarting your PC resets non-functioning USB ports, which may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure you install them.
Try connecting your player to another PC to see if the new PC recognizes it.
If it does, chances are your computer does not support the hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to recognize it.
Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable to get it to work with your PC.
http://applestore.altervista.org/mp3mp4.pdf
Aug 25, 2013 | Intel Computers & Internet
SDCard and USB won't play video
format them first,then when you finish adding files to them,finish it like it would be a cd/dvd
Apr 27, 2017 | Car Audio & Video
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
Notebook compter not recognising my mp4 player
Maybe you need to install some driver, check if your product came with a CD driver or search for the web site of the product. You need to post more information about this mp4 player to help us to help you.
Feb 26, 2010 | Microsoft Windows XP Professional
My touchscreen mp4 player wont turn on
try charging it for 2-3 hours and then try if not working after that maybe the swich is not working
Dec 30, 2008 | Digital Mind Corporation iQ Sound...
I need to know how to download music to a mp4 player.
all mp3 and MP4 players have a built in USB port for connecting it to your computer, connect a USB cable to your MP4 player and the other end of the able to your computer's available USB port, windows will recognise the drive and install it for you. all you need to do is to go to my COMPUTER and double click on your MP4 player drive to open the content of your drive
check to see that the drive is has foldes like MY MUSIC, you can use windows media player to sync music files in your library to your MP4 player.
Dec 13, 2008 | Classic Electronics MP6410 MP3 Player
Can't get the usb port to accept the mp4 player.
Switch on your Mp4 player and connect it to the usb port. Your computer should produce a message "New Hardware Detected". If you don't get such a message either the lead, the usb port or the Mp4 player is faulty.
If you do get such a message, if your computer can't find and instal the right drivers automatically there will be another message or the Found New Hardware wizard will appear. By following the onscreen instructions your computer should be able to search the internet for suitable drivers.
In any eventuality, when connected the Mp4 player should appear in the My Computer window and if it doesn't it isn't connected.
Jun 26, 2017 | Samsung YP-T9JQB Digital Media Player
Noggin
the player has to be connected to computer via USB cord one end goes into the mp3 or mp4 and the other goes into the usb port after it has charged to turn it on u have to hold the menu button down/ Thats how mine work Does anyone know how to add videos I have added pictures which looks beautiful.
Feb 19, 2008 | iLO (2 GB) MP3 Player
Philips Gogear Vibe 8gb Mp3 Mp4 Video Player 1.8" Silver Sa2vbe08s/17 Logo
222 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
