Question about Treadmill Doctor Nordictrack Powertread 2000 Treadmill Front Roller
I was cleaning a powertrex treadmill yesterday and it was working fine . tried it this morning and a fault E06 has came up . took cover of and there has been a few drops of water that has got into parts of machine
    Top Expert:
  • Treadmill Do... Master
  • 12,223 Answers
Try to use a small gun for dryer and pass for electronic board very carefully or let to dry by itself by 24 hours or add some lamps by over the electronics boards.. And try again.
If the problem persist, you must call some elect tech.to due that will be some condensation and electronic short can be ocurr.
God bless you
Posted on Dec 11, 2012
I took my 20hp power merc I just bought for a run yesterday brought it home flushed it with fresh water when I looked at it this morning there was an oil drip what is this problem?
I would have to clean the engine and then check for the source of the leak (pull all the covers off the engine), allot of work for one drop of oil.
Jan 26, 2017 | Cars & Trucks
Panel shows code error e06
tengo un error E06 tengo 2 meses que compre el equipo espero puedan ayudarme mi correo es nicolas82191@hotmail.com
Jan 03, 2013 | Lime Pro Equipment D7.3 Treadmill
Front console not working
Try this first: 1) Replace the batteries by new ones, clean the contacts batteries very well with c. cleaners.
2) adjust the REED swtich, test for open or faulty, clean it, and tigh the connector very well.
3) tight the ribbon cables inside, clean it, and tight very w.
4) see the diagram attached and try again.
God bless you
Dec 10, 2012 | Nordic Track NordicTrack T7 si Treadmill
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
Epic 450mx console lights up but nothing works not even the fan, worked fine yesterday
1) Adjust the REED switch,clean, and tigh the connector wires.see the diagram attached.
2) See inside for any fuse blown adn replace, or c.breaker reset
3) Reset the machine. Tight any connector, and wires looses, or breaker use the DVOM , see the diagram
God bless you
May 08, 2012 | Epic 450 Mx Treadmill
My gibson furnace is about 8yrs old and it was working fine heat was on yesterday morning but last night it stopped. Changed batteries in thermostat which in new(thermostat) but no heat. Checked the vents...
Look on the back of the bottom cover... it should tell you what the blinking means...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 03, 2011 | Gibson Heating & Cooling
Card error
The SAME thing is happening to mine as of yesterday.. I uploaded pics no problem yesterday morning, took more pics last night and then when I went to plug it in.. says card error. Tried other cards in my camera, its saying the same AND this card will no longer work in other readers.. Heeelp please!
Oct 30, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
My vision fitness t9450hrt stopped mid run yesterday and the belt wont move..the inclene still works and everything else works fine i have took the cover off checked the drive belt from the motor and it is...
Use your multi meter check continuity on motor leads if you get about 1 to 1.5 ohms if not leads may have open. You may also need to do calibration if the above check a ok.
Apr 15, 2010 | Dmm Vision Fitness T9500 Treadmill
JVC GR-DVM55U Error E06
HI,
"E06" it is the carriage mechanism that has failed. and will not carry the tape to the heads and thus is not passing the sensor that tells you if the tape is in position and then telling the unit as it should there is fault.
take it to the nearest dealer and get it fixed.
Aug 23, 2008 | Televison & Video
Treadmill Doctor Nordictrack Powertread 2000 Treadmill Front Roller Logo
80 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
