Question about Lenovo A65 Smartphone
Lenovo a65 failed to boot or failed to turn ON
My son playing @ my lenovo a65 then it shutdown and when i try to turn it on or do plug the charger it wont work can someone help ?
Juast full out your battery and sd card sim in 1 to 2 seconds and theback it again and press power on and plug ur charger in usb port show it if its is running ur batttery icon located in the upper right side thats all try it now
Posted on Apr 20, 2013
Battery not charging
it may be the charger. if it is you can check it. first shutdown your laptop and then take out the battetry, plug in the charger cord, then turn on the laptop. if it turns on it is not the cord, it is the battery that needs replacement. if it doesnt turn on you just have to go to staples and get a new cord
Jun 25, 2013 | Lenovo ThinkPad T61 Notebook
How can i reset my screen pattern lock since i cannot enter into main menu of my lenovo a65
go to settings. click on display settings. u would see a screen timeout message. click and adjust timer. might help
Jul 14, 2012 | Lenovo A65 3G Dual Sim Quad band Android...
My lenovo netbook s10-3 is beeping jaust a 1 beep when it is booting
try to do this:
- remove the battery and charger (everything connected to the pc) then press the power button for 1 minute.. - plug back in the charger - after few secs try to turn it on
or if beep persist try to reseat your pc memory ( make sure you know how to do it or you can try to look on local tech in your place)
if problem still persist you can contact Lenovo tech support on this number 877-453-6686
hope this helps :D
Apr 05, 2011 | Lenovo IdeaPad S10-3 Netbook
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Plugged in not charing, power available 92%
Shutdown PC. Then remove battery and Plug in AC power cable. Boot Computer. If everything fine, then shutdown again>put battery back and try! It should work. I had similar problem.
Jun 18, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
RAYMARINE A65 COMPLETE FAILURE
Was the engine running when it shut off? How was the voltage at the time it failed? The A65 will shut down if the voltage drops below 11.2 volts.
Another common cause would be corrosion on the plug where it plugs into the back of the display, or the terminal connectors that attach it to the boat's power supply.
It could also be a bad crimp on the terminal connectors. Make sure connectors are the right size for the wire and that they are marine grade, such as Ancor brand connectors. I also recommend heat shrink style connectors,
I have not heard of any software issues for that model so I am betting it's a wiring issue. However, there is an update available from Raymarine. There were changes made to the WAAS satellites and the update helps it recognize the new satellites. You can download it for free from Raymarine. Copy it onto a blank CF card and plug it into the card slot on your GPS. When you turn the unit on it will prompt you on how to proceed with the update. It will fix any known software gliches at the same time.
I hope this answer helps. Please reply if you have any questions about my response.
Feb 25, 2008 | Raymarine A65 Combo GPS...
Lenovo A65 Smartphone Logo
130 people viewed this question
Top Lenovo Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
artie g
artie g
Are you a Lenovo Audio Player and Recorder Expert? Answer questions, earn points and help others
