Question about Xerox Office Equipment & Supplies
CARTRIDGE DETACHED MESSAGE
When I put in a new cartridge I get a cartridge detached. Insert black cartridge message
SOURCE: "no cartridge" message
I'm having the same problem....let me know if ya find a solution
Posted on Sep 10, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
SOURCE: unsupported cartridge error
Unload and reload the Lexmark software........AND clean the printer contacts,
not neccessarily the cartridge contacts.........
that outta do it.
Posted on Apr 28, 2009
Muzzi_123
  • 749 Answers
SOURCE: trying to insert new black printer cartridge
your printer will not operate with the 'color' cartridge missing you will have to install a color cartridge.
Posted on May 19, 2009
  • 82 Answers
SOURCE: My dell photo 966 says'left cartridge missing
the contact that detects the left cartridge may be dirty or not functioning at all. clean it with cotton and 100\% isopropyl alchohol then reinsert the cartridge. if it still doesn't work, it must be replaced.
Posted on Nov 06, 2009
I have problem cartridge detached 093-972...fuji xerox docuprint cm 205 b
I'm having a problem with my Fuji Xerox printer model CM115w. The screen is showing cartridge detached 093-973 printer
Insert
Black Cartridge
Please help.
Apr 14, 2013 | HP LaserJet Office Equipment & Supplies
I have inserted a new black ink cartridge (34) and get an error message 'left cartridge missing, insert black or colour photo cartridge' have peeled label off and reinserted several times but still...
Make sure you are inserting a genuine Lexmark cartridge. Try to insert a different known working cartridge, maybe your old black cartridge, to determine if your new cartridge is faulty. If inserting your old black cartridge gives you a message saying "very low ink" or something to that effect, then most probably there's something wrong with the new black cartridge. Have it replaced with a new one from the store where you bought it from. You may also contact Lexmark Technical Support Center for assistance.
Aug 12, 2011 | Lexmark X8350 All-In-One InkJet Printer
I have a HP PHOTOSMART 2610 all in one printer and have developed a printing problem. This printer has been working as it should up until just recently. I have been using the Walgreen's photo service...
Because is refill.When refilled a small gap is detached to make the refilling and it no longer recognize as the brand it use.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | HP Photosmart 2610 All-In-One InkJet...
I tried replacing the printer toner-I get a message saying "Cartridge error. Put black toner cartridge back in"
Remove the "new" cartridge, and re-insert the "old" cartridge, to see if _only_ the "new" cartridge causes the error.
Otherwise, take the printer to a qualified technician.
Jan 23, 2010 | Brother MFC 7840W Printer
I keep getting the message "remove and check cartridge on right. I do this, but it doesn't solve the problem. The printer worked fine until I installed a new black ink cartridge. After so many times of...
The cartridge on the right is the black ink cartridge. The one on the left is the color.
Make sure you have pushed the cartridge in all of the way and that you have removed the tape cover from the cartridge before you insert it.
If you bought aftermarker or third party cartridges, you have a cartridge that is not filled properly. If you purchased it from a local retailer, return it and try another cartridge.
The Hp reads the levels from the gold connectors on the cartridge. If they are blocked, or damaged or the cartridge is not full, you will get this message.
Jan 14, 2010 | HP Photosmart 4180 All-in-One Printer
Error message insert black cartridge.
Just replace the black cartridge with new one.
Nov 05, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Unsupported cartridge error
Sounds like a falty cartridge. Call Dell tech support. The cartridge should have a warranty even if the printer iself does not. They'll replace it.
Feb 26, 2009 | Dell 924 All-in-One InkJet Printer
New print cartridge not printing
-detached the cartridge
-wipe the cartrdge well
-attached it back(make sure you put it in its proper way the black and color cartrged)
-unplug the switch and cable of the printer
-try print
Thank you
Nov 14, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
My Hp PSC 1350v
Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
Sep 12, 2007 | HP PSC 1350 All-In-One Thermal Printer
632 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
