Question about Panasonic Microwave Ovens
Need a service manual for Panasonic inverter assembly A606YM30
Need service manual for connecting up inverter assembly.
  • 1 more comment
  • William Donavan Dec 14, 2012
    Is the A6064A00AP the same as A606YM300XN? I know there can be a world of difference between part numbers.
  • William Miller
    William Miller Dec 18, 2012
    No, they are not the same, but there are common genral principles.
  • William Donavan Dec 18, 2012
    But is it the same input voltage? The schematic shows 120 volts, and I'm looking for 240.
  • Panasonic Master
  • 9,098 Answers
See the safety file here first.
Normally it's best to look up the microwave oven's service manual by model number and go from there, but since you didn't list that, this should help.
I have several publications including manuals and bulletins in my files covering Panasonic inverters. They are here:
http://031d26d.namesecurehost.com/mwd/bulletin_inverter_repair_kits.pdf
http://031d26d.namesecurehost.com/mwd/inverter_files.txt
http://031d26d.namesecurehost.com/mwd/panasonic_Inverter.pdf
http://031d26d.namesecurehost.com/mwd/panasonic_inverter_and_info.htm
http://031d26d.namesecurehost.com/mwd/panasonic_inverter_microwave_testing.txt
http://031d26d.namesecurehost.com/mwd/panasonic_inverter_models_trouble_codes_sm.pdf
http://031d26d.namesecurehost.com/mwd/panasonic_inverter_parts.txt
http://031d26d.namesecurehost.com/mwd/panasonic_inverters.pdf
http://031d26d.namesecurehost.com/mwd/Panasonic_NN-G62BH_A606Y4T00AP_inverter.pdf
You can order Panasonic parts from Encompass here.
Posted on Dec 11, 2012
Hi I have a Panasonic NN SN 797S. works perfectly for say 20 mins and then blows a fuse. Replace the fuse and it may work for 2 days or 10 mins and then a fuse blows again. I was told the noise filter
Is the internal cooling fan working when you cook?
If not, the magnetron will overheat, and the unit will draw excessive current.
Otherwise, I would suspect the inverter.
Due to the complexity and lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on repairing an inverter.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
The service manual is here.
You can order Panasonic parts & accessories from Encompass here or you can call them toll-free at 866-779-5835.
Dec 01, 2013 | Panasonic Microwave Ovens
My panaonic microwave stops after 5 seconds and H98 appears in the display window.
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
Dec 27, 2012 | Panasonic Microwave Ovens
Panasonic Microwave Oven starts for 5 seconds then shuts off
If it stops after exactly 7 seconds, it has a problem with the inverter.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Dec 25, 2012 | Microwave Ovens
1200 watt panasonic genius shuts down
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
May 26, 2010 | Panasonic Microwave Ovens
My panasonic inverter microwave model no NN-T523M switchs off after 5 secondsno matter what setting. the digital screen says consult manual, which has been misplaced
You can find Panasonic owner's manuals here.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If you decide to replace your inverter, you can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
May 15, 2010 | Panasonic Microwave Ovens
Turn off after 2 sec
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
You can find many Panasonic owner's manuals for free download here.
If you're not in the US, see Panasonic.net.
Nov 23, 2009 | Panasonic Microwave Ovens
I have a panasonic slimline combi NN A554W which was not cheap. worked well until this week. put timer on to microwave and it goes down 5 secs then turns of. A clicking noise can be heard. Clock working....
, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
In Canada, you can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Oct 06, 2009 | Panasonic Microwave Ovens
INSTRUCTION MANUAL FOR PANASONIC INVERTER NN-SD376S
Desperately need
INSTRUCTION MANUAL FOR PANASONIC INVERTER NN-K593MF. please help
Jul 20, 2009 | Microwave Ovens
NNC2000P - Microwave does not work but convection works
An IGBT is an insulated gate bipolar transistor - sort of a hybird between a bipolar transistor and a MOSFET.
These are the final output driver transistors in the high-voltage inverter.
If it stops after 7 seconds, it still has a problem with the inverter.
It's likely a bad transistor, an electrolytic capacitor with an internal short or bad ESR or altered value, bad connection on the inverter board, a shorted diode or blown resistor, or a bad connection in the wiring.
Reputable service centers will have a repair warranty, but it may only be 30-90 days.
You should use a Panasonic-authorized service center so they'll have the service manual and (hopefully) experience and training to repair inverters.
In the US, you can find an authorized Panasonic servicer here.
This sounds like a non-US model. If so, visit panasonic.net, find your home country, then find the service / support links.
Feb 13, 2009 | Panasonic NN-C994S Convection/Microwave...
Panasonic nn-sn667b 1300w dead
You might consider just replacing the inverter assembly itself.
It will cost more than replacing the bad discrete components of course, but you would be avoiding the time and money involved in parts research, trial and error, and possible destruction of any newly installed parts if there remain other undiscovered defective components.
The inverter assembly (part # F606Y8M00AP) can be had for $79.12 here.
Otherwise, you would need to order the service manual, which is not listed by the major Panasonic distributors.
The service manual should be # SM-NNSN667.
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
In this case, call might be more productive to track down the service manual.
Good luck, and be safe.
Dec 24, 2008 | Panasonic NN-S954WF Microwave Oven
Microwave Ovens Logo
296 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
