Question about Panasonic CW-1006FU Air Conditioner
Panasonic r410a error code 97 - Panasonic CW-1006FU Air Conditioner
  • kjell_ove_vi
    kjell_ove_vi Dec 13, 2012
    Our iNverter Stops after a few minutes , timer lamp flashes . Check function gives 97 as code for what is wrong.
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
How too solve daikin error code c4
c4 error code has nothing to do with outdoor pcb. Use code 41 to check the value of the liquid line sensor and test with mulit meter. Pretty rare fault. Turn the power off for 5
Mins and reboot your system.
Nov 10, 2014 | Cfm Daikin R410a Split System Air...
Solution for u2 error
it sound like the outdoor pcb has failed, if your unit is less then 5 years old it will be under warranty. if your unit is a rxd50/60/71jvea it will be a fan motor and pcb
Mar 16, 2012 | Cfm Daikin R410a Split System Air...
Panasonic air conditioner cs e28gkr, has error code f97.
f-97 out door compressor over heating due to in sufficient refrigerant. Check leak and arres ***. do gas charging.
Jan 01, 2011 | Panasonic Heating & Cooling
How to reset the error code on daikin aircon
more info needed. try fixing the problem then turn unit of at the main power wait for 10 mins then turn on? whats the error code?
Nov 06, 2010 | Cfm Daikin R410a Split System Air...
My Ac wont turn on becauser the timer light is blinking Panasonic inverter R410A
use the remote to retrieve error code,on the bottom of the remote you will see a CHECK bottom,use a pointed pin to press it for 5 seconds the display of the remote will change to two underscore, then scroll the arrow beside the time,r press until you hear beep sound, then jot down the error code..there's a error code you will see inside the panel of the indoor unit,for quitting press again for 5 seconds the Check bottom
Aug 22, 2010 | Panasonic CW-1006FU Air Conditioner
Senville Mini Split Error Code
thanks for your question, you will need a set of gauges on the unit to determine if the unit came precharged, if it didn't then you will need to vacuum down the unit, at least three times, after each time release a little 410a into the system them evacuate again, 410a is bad for drawing moisture, did you put an in-line filter dryer on as well ? after you find out about the freon level, then look at the name plate rating for amount of 410a needed, before adding the freon, use nitrogen to leak check the system, then weigh in the proper amount of 410a, unit should run really well after that, hope that helped, thanks again for your question, please feel free to come back if you have any more questions, thanks, mr.grzz
Jan 21, 2009 | Heating & Cooling
Panasonic CW-1006FU Air Conditioner Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
