Question about Gigabyte Technology gigabyte Ga-78lmt-USB3 Socket Am3/ Amd 760g/ Ddr3/ USB3.0/ A&Gbe/ Microatx Motherboard
CPU fan & PSU fan working but No display coming to the screen
I am making my own computer and buyed AMD FX-8150 cpu processor which needs AM3+ socket supported Mobo, so i bought Gigabyte GA-78LMT-USB3 Mobo and also Transcend 4 gb 1333 Mhz ram and Cooler Master Thunder 600 Watts PSU and started assembling the units and finally found that power is flowing throught PSU/SMPS which also entered MOBO & made processor fan to work and also processor is getting heated up which means Processor is working.But the main problem is when it is connected to a moniter through VGA cable and also Keyboard to the Mobo, There is no display on the screen and also found Keyboard lights are also not working... Mobo is brand new and i dont know where is the wrong happened. All the circuits were also built according to the Mobo guide only !
  • Ananth Ram
    Ananth Ram Dec 11, 2012
    Thanks for your concern, you have chosen another mother board which is GA-78LMT-S2P but what i told is GA-78LMT-USB3 this is another type of motherboard and here is the link for the cpu supported list and you can see FX-8150 is in the supported list
  • 2,878 Answers
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Posted on Dec 11, 2012
  • Ananth Ram
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Nfs is laggy in my fx6300 is it a processor problem
Check your CPU temperature. That could make your PC run poorly. If it's warm, you might have to reseat the CPU cooler with fresh thermal paste or get a better CPU cooler. Also, try a malware scan in Safe Mode. Malware will make your PC run poorly as well.
Apr 30, 2014 | AMD FX Six-Core Processor Model FX-6300...
Recently ntly bought a new processor fx 6300 AMD
Could be a cable routing problem; interfering with other cables . Try re routing/separating the loom.
Oct 27, 2013 | AMD FX Six-Core Processor Model FX-6300...
I just did a complete new build of a computer using the Elitegroup ECS A885GM-A2 board. It powers on, shows an LED on the board, but does not beep and there is no display whatsoever. All the fans ar
usually this means that the board is powered on, but that the cpu hasn't been initialized. make sure your cpu pins are clean of thermal grease and that it is properly seated. make sure your board is compatible with the cpu and if you can get a spare (known good) cpu to boot the board with, see if it starts, and see if you can update the bios.
again, basically the issue is CPU related. at some point you may have to just RMA the processor since it is a possibility that it might be DOA. good luck!
Feb 17, 2012 | EliteGroup ECS A885GM-A2 (V1.1) AM3 AMD...
Can Amd AM2+ GEFORCE7050MM v2 mobo able to support AM3 Processor?
Yes the mainboard should be able to support an AMD AM3 CPU, however the mainboard will not be able to make as good use out of the CPU as an AM3 mainboard would.
AM2+ will use DDR2 800MHz RAM whereas AM3 uses DDR3 1333MHz or higher for example.
It's specification tells us that it is supported as it is labeled AM2+ the + stands for AM3 CPU's as well.
Take care and happy upgrade!
damnor01
Jun 10, 2011 | EliteGroup Amd AM2+ GEFORCE7050MM...
Need a heatsink that will fit MSI 870-G45 Motherboard (Model # MS-7599). CPU is AMD Phenom II X4.
You can find heatsinks at the following link, you will need one that is compatible with
AM3 AMD 770 ATX AMD motherboards
If you look through each product, it will show you compatibility or you can filter search results.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=574&name=CPU-Fans-Heatsinks
Regards,
G33k
May 05, 2011 | AMD Computers & Internet
Is it alroght to use this fan on an AMD Phenom X4 9450e Quad core Processor? Is is adquate?
It will work but I'd personally not use it as a long term prospect. Given the cpu you have, I'd buy a better spec model with more comprehensive cooling
Jan 25, 2011 | Cooler Master DK8-7G52B-A2-GP CPU Fan -...
Hello again, Upgrading CPU's
Your board supports socket AM2 CPUs the fastest of which is the AMD Athlon 64 X2 6000+ dual-core processor at 3.1 GHz.
Your motherboard does not accept socket AM3 CPUs.
Dec 15, 2009 | Computers & Internet
CPU fan does not stay on
Sounds like either the PSU or a part (CPU) on the motherboard overheated and fried.
How do you know that the PSU is good? Did you take it out and try it in another computer? If not I would try a new power supply first.
Dec 27, 2007 | Global Win K7 T.Bird Socket 462 Cooling...
Gigabyte Technology gigabyte Ga-78lmt-USB3 Socket Am3/ Amd 760g/ Ddr3/ USB3.0/ A&Gbe/ Microatx Motherboard Logo
275 people viewed this question
Top Gigabyte Technology Computers & Internet Experts
David Payne
David Payne
Are you a Gigabyte Technology Computer and Internet Expert? Answer questions, earn points and help others
