Question about Electrical Supplies
We have Olympian power generator Model GEP 100, The Problem is after servicing the injector and fixing it, it starts nicely, but when in running a black smock comes out non stop, what should i do so
Olympian GEP 100
3 Suggested Answers
sal_kh_sab
  • 98 Answers
SOURCE: our onan generater runs but the power in the rv comes & off,
if ur problem is why does it get loud when the power is off...the answer is GLATOR calibaration..
if u have any further questions email me at sal_kh_sab@yahoo.com
Posted on Oct 15, 2009
  • 905 Answers
SOURCE: Powermate model 544000 generator undervoltage
There are basically 2 possibilities that can cause this.
1) Enigne RPMs are too low. but, since you already played with the throttle, this probably isn't the case. RPMs should be about 3600 though.
2) The voltage regulator / capacitor has high ESR (resistance) or is bad altogether. Replace.
Posted on Jan 04, 2010
Olympian generator g15u35 wont stay running. Shows fail to start fault.
Check the oil level, and oil level sensor. These are common issues with generators such as this.
Oct 16, 2014 | Electrical Supplies
55kva gfwison generatore having trouble of no output voltage showing nor it feeding
If it is an FG Wilson 55KW Olympian you need to check the AVR and make sure it has a field output feeding the exciter stator, then check the rotor diodes, check each one with a meter, low res one way high the other with meter leads. If any are bad change them all, check the exciter rotor, then the main rotor and stator for open or shorted windings. If you give me the exact model I can maybe help more
Oct 06, 2013 | Electrical Supplies
Olympian generator
I am ssuming this is a 50HZ unit? hence the engine speed with a 4 pole rotor which this has is 1500rpm. I also assume it is not one you are trying to convert from 60HZ to 50HZ? You never said what your countries voltage is? I assume when you say 400V is too high, you are looking at a 380V 3 phase power???
Based on that the engine speed is controlled by the governor control board, and if electronic Isy governor installed can be adkusted with a potentiometer. If youa re trying to slow down a 60HZ unit to 50HZ it won't work as you will get under freq fault.
The voltage is governed by a small AVR PCB in the alternator cover. pos an SX series AVR
Sep 20, 2013 | Electrical Supplies
Keeps stopping
which type of generator had an Olympian GP18 which would start and stop immediately, we were suspecting that the emergency switch had been pressed and left on but it so happened that the starter relay was the one loose.
Regards
George
Sep 01, 2012 | Cars & Trucks
Coleman Powermate 5000w generator sputters
you dont say if diesel / petrol.
if petrol check the choke mechanisim.
if diesel injector may need cleaning or re setting
Mar 17, 2010 | Coleman Powermate Powermate 5000W...
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
Jan 20, 2009 | Generac Guardian 100 Amp Transfer Switch...
Connecting to Google Earth Plus via Tiscali
check your internet settings..
As you said you are new to this..
the best thing is RE-INSTALLING GEP
This will surely solve your problem.
Oct 21, 2008 | Computers & Internet
Electrical Supplies Logo
44 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
