Question about Sylvania Electric Stove Heater, Black Model S211 - Quality Craft Home Decor
Why does my sylvania electric fireplace Model S211 squeal
The heater squeals from the time you start the flames since you have to turn them on first. it makes a squealing/rubbing sound. even after the thermostat kicks off it still makes noise. I need help since I bought this as a Christmas gift.
I had the same problem. If you remove the top row of screws on the backside of the unit, you'll see that the flame effect is created by a series of reflectors attached to a rod. Turning on the unit activates a motor that turns the rod. You'll see that the other end of the rod is just a loose end that is allowed to turn inside a plastic holder. Unfortunately, the rod rubbing against the plastic as it turns causes the annoying squealing sound. I solved the problem by wrapping a small amount of paper towel around the rod, pushing the PT into place inside that plastic rod-holder, and spraying it with a little bit of WD-40. I had to remove the entire back panel to get proper access. No more squealing noise (for now)! Time will tell if I need to reapply the WD-40.
Posted on Jan 18, 2013
Our fireplace is 22 years old and we are not able to start the fireplace.
Is this a flame effect electric fireplace with a fan heater underneath it?
If it is, the bulb has gone. Remove the coal or logs and remove the cover. You will see the bulb.
Dec 29, 2015 | Heating & Cooling
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Purchased a great world model swe071 electric fireplace. How do you control the feature to make the flame colors change automatically without using the remote every few minutes. Lost manual
I bought a great world ltd swe067b electric fireplace ... - Fixya
www.fixya.com/.../t25420081-bought_great_world_ltd_swe067b_electri...
Feb 12, 2015 - i bought a great world ltd swe067b electric fireplace a couple of months ago.it wont ... Purchased a great world model swe071 electric fireplace. Howdo you control the feature to make the flame colors change automatically ..
Oct 25, 2015 | World Heating & Cooling
Purchased a Great World Ltd electric fireplace at BigLots. Model is either SWEO71 or SWE071. The flame and dimmer features are not working. Just put it together and mounted on wall, turned on, and
don't know this model, but does it have a light bulb inside? if so change it. they are often red or orange, but any will do to test it
Sep 13, 2014 | Heating & Cooling
Sylvania electric stove heater, black (model SO111R-MBK) stopped working
Got a stove electric space heater But it will not trunk on just the flame button but no flames and no heat what can I do to fix this .boxes the remote control have to light up....Albert Gomez..2124 North Keeler ave..Chicago Illinois..60639...18722062470.....
Dec 08, 2012 | Sylvania Electric Stove Heater, Black...
My Rheem powervent2 water heater squeals while running
The power vent motor squeals when burner is activated?
See if you can oil the power vent motor.
http://waterheatertimer.org/images/Anode-under-blower-200.jpg
If the water heater squeals when water is turned on, then remove heat trap nipples and inserts and install di-electric nipples from water heater department local home store.
Copy following link illustrations.
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Additional link:
Troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Oct 08, 2012 | Rheem Water Heaters
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Sylvania Electric Stove Heater, Black Model S211 - Quality Craft Home Decor Logo
392 people viewed this question
Top Sylvania Heating & Cooling Experts
tractorman44
tractorman44
Rani wadia
Rani wadia
Jay Plesset
Are you a Sylvania Heating and Cooling Expert? Answer questions, earn points and help others
