Question about Canon i-SENSYS FAX-L160 Laser Fax Machine
Change baud rate canon l160
I need to change the BAUD rate to 9600 and turn off error correction control
3 Suggested Answers
  • 1335 Answers
SOURCE: How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Posted on Apr 29, 2010
FixinFax
  • 3085 Answers
SOURCE: where do I find Baud 9600 Rate and ECM?
You can't, plus it will not help on a digital phone system. ALL fax machines are ANALOG devices.
Posted on Jun 29, 2010
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Baud rate hp 9600
why need to change baud rate, no need to change???
because it is not a serial port printing it is usb port printing....?
Oct 01, 2013 | HEWLETT-PACKARD LaserJet M1522nf...
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Need to the baud rate how do you do it
Enter Maintenance Mode:
1. Unplug power from rear of Fax machine, hold the Menu button while plugging power back in. Continue to hold the Menu button until "Maintenance" appears in the LCD window.
2. There are no helps for the Maintenance mode. Follow parameter change procedures to the letter.
Changing Baud Rate from Automatic to 9600:
1. Enter 10 (one, zero). This will bring up WSW00 on the LCD window.
2. Change the 00 to 19. If the baud rate is set to automatic, the numbers that appear will be 11100010.
3. Change the 11100010 to 01100010. This sets the baud rate to 9600.
4. Press the "Set" button just below the LCD window.
5. Press "Stop".
6. Enter 99. This will exit Maintenance mode and make the fax ready to use again.
Feb 15, 2011 | Brother IntelliFax-4100e Fax
Where do I find Baud 9600 Rate and ECM?
Jun 29, 2010 | Canon imageCLASS D480 Black and White...
4800 baud rate communication in vb
You have to change it on both side!
If you are communicating your PC with a serial device, BOTH must have the same speed (serial device: 4800, pc: 4800)
Have you done it?
Most devices DEFAULT settings are 9600 baud rate, N, stopbit1.
But you can change it depending on the device...
Jan 03, 2009 | Computers & Internet
Baud rate
1. Why 9600?
Because you are using a VOIP service it can from time to time lose connection briefly. The slower the speed the less data can be loss do to network congestion. It also gives the error correcting function of the receiving fax a better chance of filling in any lost data.
9600 is a good choice becasue the industry minimum is 9600. This means you will be able to communicate pretty much any fax thats is still tickin today. Raising the speed will get you a faster transfer but will also increase the chance that you are sending data at a faster rate than the recieving fax can send.
2. How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps.
May 28, 2008 | Brother IntelliFax-2820 Laser Fax
Baud rate
# Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill it gets to ADVANCED FAX.
2. Press Select.
3. Press Options untill it getsl MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
# Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press Option untill it gets to ADVANCED FAX.
2. Press Select.
3. Press Options until ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes.
Mar 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Change baud rate
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Dec 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
    Canon i-SENSYS FAX-L160 Laser Fax Machine Logo
    75 people viewed this question
    old marine
    old marine
