Question about Razor E200/300 Electric Scooter Battery
Where can I buy a new battery charger for my E200 Electric Scooter
    New Friend:
Wheel Gears provide the best Review of the Electric Scooter; customers can view the multiple Reviews different Electric Scooters and they have a chance to select best one. http://wheelgears.com/
Wheel Gears
Posted on Sep 15, 2017
  • 7 Answers
SOURCE: razor e200 runs slow
you need a new battery they cost about 35$ on razor
Posted on Jun 08, 2009
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Posted on Jul 19, 2009
  • 38 Answers
SOURCE: How can I put chain back on my E200 razor electric
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
Posted on Aug 18, 2010
  • 38 Answers
SOURCE: re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
  • 15 Answers
SOURCE: we have E200 razor electric scooter. it shows
needs new battery.
Posted on Jan 10, 2011
Razor e200 power scooter goes very slow
the battery is probably dying out and you need a new one, or need to charge
Jun 23, 2012 | Razor E200 Electric Scooter Green
Tip
How To Change Replace Battery on a Electric Razor Scooter E200
<utube src="iR-CZ_uOvOo"></utube>This Video will show you how to replace or change the battery on your Razor E200 electric scooter.
on Aug 04, 2013 | Razor E300 Scooter
My sons razor e200 dies quickly. I have changed the batteries, brought a new charger. I have checked the connectors and the tires are not flat The light is green but after 25 yds, turns and says needs to...
Problem is not the batteries then. Replace the controller. The controller could be resisting some of the charging current to the battery.
But first try this:
Charger the scooter with it OFF
Directly connect the charger to the battery
If still the same problem then:
Directly connect the charger to the battery then,
connect the motor leads directly to the battery and see how long it runs. It with new the batteries it should run longer than a minute. If it does than something is definitively wrong with the controller.
Aug 15, 2010 | Razor E200/300 Electric Scooter Battery
We have A 300 razor battery scooter but do not have the battery pack or the charger.
Buy a replacement battery pack and charger at razor.com or http://electricscooterparts.com/razore300.html
Jul 10, 2010 | Razor E200/300 Electric Scooter Battery
What do you do when ur razor e200 electric scooter stops working?
First try charging the battery, if that doesn't work then replace the batteries with replacements from razor.com. This should solve your problem
Jan 15, 2010 | Razor E200/300 Electric Scooter Battery
Ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Apr 15, 2009 | Electric Currie EZIP 500 Scooter
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Razor E200/300 Electric Scooter Battery Logo
140 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
