Question about Neff H7871 Convection/Microwave Oven
After approx a minute a regular squeak begins, occasionally missing a beat.Heating is fine.
As microwave oven heats up a squeak starts,approx each second,occasionally intermittent,appears to be in time with a fan or some revolving mechanism.Oven works fine but this bearing kind of squeak is irritating
  • Neff Master
  • 9,086 Answers
If the "frequency" of the squeaking is a low frequency, the I would suspect the turntable motor or stirrer motor (if so equipped).
If it is a higher frequency, I would suspect the cooling fan or hood fan motor.
Posted on Dec 12, 2012
4 Suggested Answers
beltronic205
  • 1474 Answers
SOURCE: Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Posted on Apr 20, 2010
heatman101
  • 43501 Answers
SOURCE: not heating or defrosting although light works, timer etc works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjfh
Posted on Sep 30, 2010
  • 228 Answers
SOURCE: Noisy Fan in Neff Combi Microwave/Oven. B6774.0gb
yes you can fix it yourself it is a cooling fan in the top it is round metal fan quite small venting waste fumes from cavity when grilling etc need to remove top panel and 3 screws to remove it is a push in fit.
Posted on Oct 28, 2009
How do you use the kitchen timer and cook at the same time?
If you have the kitchen timer set for instance for 10 minutes and it is counting down, and then you want to reheat you coffee for 2 minutes. You would hit either time cook or reheat button and enter 2 minutes ten hit start. The microwave will heat your coffee and show the 2 minute countdown for that. When done it will revert back to what is left on the 10 minute kitchen timer without missing a beat on most microwaves.
Feb 26, 2015 | Microwave Ovens
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
Maytag microwave cook delay - first minute on timer no heating, then works fine
Not a feature I've heard of.
I would do a hard reset by unplugging the oven for a minute or two, setting the clock, then trying again.
If it still does this, I would contact Maytag customer service at the number in the owner's manual.
Dec 25, 2012 | Maytag MMV6180WS Over the Range Microwaves
Frigidaire FMV156DC 950 Microwave sometimes stops heating
This sounds like a common primary interlock switch. Need to check and or replace both door switches. DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Frigidaire FMV156DC Microwave Oven
No fan and short time heat, did something get knocked loose in transition?
Power control is accomplished by turning magnetron on and off at different intervals. Check when cooking if power is coming on and going off at regular intervals. Time these intervals and see if they are random or regular.
Mar 21, 2017 | Whirlpool WMH1162XV Microwave Oven
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Microwave runs, stops and counts down, starts again, etc.
It sounds like its over heating or the magnatron or the Hi voltage transformer. if you open it and start it a fan should be cooling off the magnatron if its not then the fan is bad and thats your problem Worse case is that the power transformers drawing too much current and over heating and shutting down the first problem i explained though I've seen a hundred times. BUT BE very carefull as there is hi voltage inside this puppy and I've seen it grab and throw a grown man across the room!!!! if you know nothing about electrical or electronic devices its best that you leave this repair to a pro. Good Luck
May 04, 2006 | Amana AMV1162 Microwave Oven
Neff H7871 Convection/Microwave Oven Logo
735 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
