My zoom g1xn suddenly stopped working. When i connect the power source, it doesn't turn on. . . When i tried batteries, i turned on but the display was flickering then it turned off. . . What is wrong?
  • 7,627 Answers
Try another cord/charger. Check the AC jack in the machine. Is the battery charging with the cord/charger plug in? Has the laptop AC jack been pulled by the cord? Damaged?
Posted on Dec 11, 2012
4 Suggested Answers
  • 70 Answers
SOURCE: Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Posted on Jan 21, 2009
KingOfKYA
  • 94 Answers
SOURCE: When playing games like grand theft auto san
Sounds like a overheating issuse. Get a can of air or vacuum and blow out any vents.
Also avoid playing games on any soft surface couch bed etc. As that blocks the fans.
If that dosen't fix it it is most likely the GPU on the motherboard overheating and lifting off the board. It is a very common problem.
Posted on Jun 13, 2011
bendarden
  • 984 Answers
SOURCE: won't turn on or charge
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.
I'm writing this on my Aspire One and it's a great piece of equipment.
My initial opinion is that you have a defective adapter. However, let's try a few diagnostics.
Please do the following carefully:
1. Shutdown and Unplug your laptop.
2. Remove the battery from the laptop.
3. Wait 2-3 minutes
4. Now press ON (power button on laptop) for 1 minute
5. Then release the button and wait one more minute.
6. Now plug in the power cable (don't insert battery yet) and press ON button.
7. Did your screen light up or flicker ?
If you got negative results, I'm now pretty certain that it's the adapter but we'll struggle on. If the adapter is defective, it will not charge up the laptop and your problem is consistent with that malfunction. You can check the output of the adapter with a multimeter. You should get a reading of seventeen (17) volts DC.
Now you can check two more items things :
1. Try re-inserting the RAM (memory modules) - do this first.
2. Bios battery. It is a button type battery located inside your laptop. Replace it with new one.
If this has all proven to be ineffectual, then your motherboard or the electrical input circuitry is defective. That being the case, my advice is to have Aspire repair it. or ram (and maybe display too) is damaged. You need to get it repaired or replaced. (hopefully it is still in the warranty period)
Whatever, you may decide, don't invest more than $75 because you can buy a new on with 2 GB of memory for under $130 on eBay.
You might find the tutorial video of some help. Just click below.
Posted on May 22, 2012
I have Zoom G1XN ext. My guitar effect just lit "Gn" and can't change to Bank memmory. I need the circuit diagram and service code for Zoom G1XN ext whom can help and send to my email dias.no1@gmail.com
Have you tried to reset the unit? You can do this by holding save button for few seconds while connecting your adaptor to g1x/g1xn. Then the indicator will blink, then push save button again,this will reset your unit into its factory settings
Jul 12, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
It blinks with "be" and turns off
It may be "but" that you're seeing, which indicates the batteries are low. Use the AC adapter made just for this model only, and the guitar needs to be plugged in to turn the unit on. A full manual for this Zoom model can be found here:
https://www.zoom-na.com/sites/default/files/products/downloads/pdfs/E_G1_G1X_3.pdf
Dec 01, 2013 | Zoom Samson Technology Zoom G1XN Multi...
No power or display when I turn on the gadget, even using battery, it will display sometimes but a blink oh "be" letter appears on the screen
Zomm g1xn software problems
Yes, it's a hardware problems. Try using the battery.
If the result is the same,there is a possibility of damage to the processor IC (ZFX3). But before be sure, try measuring the voltage as in the image below :
Stuck in GN display usually appears because 1.8Volt voltage is not normal (or no voltage at all), and in general, it is caused by damage ic ZFX3.
Leave it to the experts to be repaired. If it really ZFX 3 is the case, then this can not be fixed, because ic ZFX3 not sold to the public. If you call the authorized service ZOOM, you may be able to buy G1XN mainboard. 11399294-xykdzr1cdriwl1tmr4ngy0qt-2-3.jpg
Jan 22, 2012 | Zoom Samson Technology Zoom G1XN Multi...
My iphone cannot turn on.....i tried all the solution in this forum and still my iphone does not turn on....pls help.
Have you tested it with another battery?
Make sure the battery is good.
Make sure the battery is connected to the iphone properly. That is, check the battery terminal.
If the above doesn't solve the problem, then it means the iphone has developed a power problem.
Regards.
Jan 16, 2012 | Apple iPhone Smartphone
2002 Pontiac Grand Prix - I put the key in and turn to start, I hear a click, then it doesn't start - in fact the entire car suddenly goes dead and the key gets stuck in the ignition. I can press the...
The first thing I would do is clean your battery connections very good. you may have to remove the plastic covers off the cable ends to get them cleaned good. Also make sure you get the connection bolts tight.
Sep 04, 2011 | 2002 Pontiac Grand Prix
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
