Question about HP Photosmart R817 Digital Camera
Images are green on camera and on screen session referenca # 922077
I think, .you should change the photo shooting mode.otherwise you reset your whole camera settings.if the problems will continue then you will change your lcd screen.
Posted on Jan 13, 2009
Is there any way to turn off the screen of a Nikon D3300 whet is conected to the pc by USB?
The screen stays on so that you can monitor the activity taking place.
BTW, it is not advisable to use battery power when transferring images to the computer, since if the camera runs out of power partway through, all images on the card may be corrupted. Use the mains lead - it is what it is for. Alternatively, transfer the images by using a USB card reader, and placing the memory card in that.
Nov 04, 2017 | Nikon Cameras
Pentax Optio Rs1000 has a green tint on screen
I have the same problem to.Do u mind to teach me how to fix it?I mean the step to fix the green screen?I have try to change many mode but the reseult is still same.Also i do transfer some of the images that i took to computer but still the image that i took is in green color.Kindly please assist me.
Jun 24, 2012 | Pentax Optio RS1000 Digital Camera
I SEE the green light when I turn on the camera but LCD screen of Sony DSC-F505V is dark black, nothing happens-total silence and cannot take any pictures. Did I loose my camera? Solution?
Based on the information provided it seems that the issue may be with the LCD Screen. You can check if the Camera is working by capturing images and inserting the Memory Stick in the Computer Memory Card slot. If the image capturing is normal then the images can be saved to the Computer. If the images are not getting captured, then the issue may be with the Camera. We can try power resetting the Camera to resolve the issue.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
If the issue persists after resetting, then service may be required to identify the exact cause.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-F505V Digital Camera
Lately every picture taken looks green....?!
This is a common problem. Check the previous images saved. If even the saved images/video's looked green, this confirms defective LCD screen. If saved images are fine, then this is highly suggestive of faulty CCD sensor.
If that is LCD screen, it could be an expensive deal to get it replaced as compared to the cost of the product. However, if it is CCD sensor, you could contact Kodak and see, if there is any recall for it as in the past, there were certain recalls due to CCD sensor.
http://www.imaging-resource.com/badccds.html
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 21, 2010 | Kodak EASYSHARE Z1485 IS Digital Camera
Impossible to connect camera with PC. no driver in the PC for camera powershot A510. What's the matter?
Just figured this one out. Man, they don't make it easy. I'm borrowing my roommate's PowerShot A510 and since it has a USB port going out, I'd assume I could simply connect the camera to my PC and access my images directly. Almost every other camera I've seen will register itself to Windows as a straight USB connection (prompting the Windows screen asking how you want to open the connection - 'open folder' etc). This one just sits dead quiet about things :)
If you've just bought this camera at a garage sale or are borrowing it or for whatever other reason do not have the "bundled" software and driver CD or have the camera's serial number, do not bother trying to find windows drivers or try to obtain any software from Canon. You won't get very far.
FINALLY found the solution in the User's Manual (which was free thank God). You can download the manual here: http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510#BrochuresAndManuals
(Select your operating system and download the "PowerShot A520/A510 Camera User Guide". File name is PSA520510CUG-EN.pdf)
In the User Guide, page 107 (I'll paraphrase):
1. Put camera in Play mode (the switch on the back (green arrow in green box)
2. Press Menu button (center one of the three along the bottom of the view screen)
3. In the 1st menu option (Play Menu, again green arrow in box highlighted), use the wheel button to scroll down to highlight "Transfer Order". Press Set (center of wheel).
4. You should now see "Transfer Order (DPOF) at the top of the screen and "Qty. of images 0".
5. Below "Qty of images 0" you'll see "Order", "Mark All", and "Reset". Order lets you select individual images; Mark All marks all current images for transfer; and Reset is reset. Press Set to choose.
Note: pressing the Menu button while selecting images brings you back to this main screen. If you are already at this main screen and you aren't ready to do your transfer yet, DON'T press the Menu button from this screen as it will initiate the transfer to your computer. Not a horrible thing, but might cause a mini freak-out.
7. Once you're selected the images you want to transfer, from the main Transfer Order window (now showing "Qty. of images" with a count of the images you selected), press the Menu button.
8. You'll see a white progress bar at the bottom of the screen. Don't worry! it's not deleting files or something bad.. (my first thoughts :) ..
9. Go to your PC and Voila! the Windows AutoPlay screen is now active!
10. Proceed with normal Windows USB operations (transferring at least, I didn't try any deletion).
I hope this helps somebody else out there who spent the last 3 hours trying to dig through internet hell to get this to work.
Atm, this is as much as I know so I probably don't have any good answers for any questions. Sorry :))
But, hope this helped at least!
Mar 12, 2010 | Canon PowerShot A510 Digital Camera
CCd failure
This is a good blog on CCD failure; http://www.teleplancamerarepair.com/camera-repair-blog/post/images-apear-to-be-distorted-e28093-images-do-not-apear-e28093-Might-be-the-CCD.aspx
Goes into the distorted images you describe, explains why it fails, what it looks like and how to fix it.
While the images actually look cool it's a real drag when it happens to your camera!
Other things that happen is the images do not appear, or show with a magenta hue, or green tint.
Mar 31, 2009 | HP Photosmart 945 Digital Camera
Images not recording
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
Jan 03, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Problems with SVP MP-585 Digital Camera
please rate my chat session as per your satisfaction
Jun 23, 2008 | Cameras
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
HP Photosmart R817 Digital Camera Logo
62 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
