Question about Whirlpool Washing Machines
Whirlpool ultimate care 2 will not spin dry
Tub does not spin at all. just makes a funny noise when it is supposed to be spinning
  • Whirlpool Master
  • 17,130 Answers
When the spin mode is on it is important to take an careful test and observation on the motor voltage, speed, the agitator spindle and belt.
If the motor is tripping it can be related to high load or friction in the spindle. Check the bearings.
Also check the capacitor to the motor.
Posted on Dec 11, 2012
4 Suggested Answers
mark_37388
  • 100 Answers
SOURCE: Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Posted on Mar 29, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
  • 67 Answers
SOURCE: Whirlpool Ultimate Care II - making funny noise
this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
Posted on Aug 11, 2009
My Whirlpool Gold Ultimate Care washer doesnt agitate or spin. Makes a strange almost clicking like noise instead.
sounds like the drive block under the tub is stripped out or broken and it needs replacing,it sits under the tub to help drive the tub on direct drive models
Jul 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool ultimate care 2 washing machine commercial use. it its making a lot of noise I believe when spinning cycle changes as if the brakes are coming on noise gettting worse other than that...
here is one trick to do. put the timer on spin and pull out the timer knob. open the lid and use a screw driver to actuate the lid switch. then with your other hand hold the agitator until the tub gets to a high spin. once the unit is at a high spin then let go of the agitator. let the unit spin for another minute then lift up you screw driver. it should come to a gradual stop and not a sudden stop. let me konw if that works.
Oct 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Mar 29, 2009 | Whirlpool Washing Machines
The motor will not spin..... can i have a diagram of a motor of ultimate care ii washing machine
The typical problems with "the motor will not spin" is a:
1. Lid-switch (very frequent): Will not drain, incomplete cycling, switch ultimately passes power to motor.
2. Belt or coupling (very frequent) - Belt moves when motor spins
3. Timer/control board (rare)
4. Tranmission (rare)
5. Motor (somewhat rare)
How do you know the actual motor is not spinning? Do you mean, the tub not spinning? Do you have a noise as if the motor is spinning?
Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care ll Quiet wash Model # LSQ9564SQ0
The ***** part of the agitator is supposed to ratchet in the clockwise direction. this is normal. If you can spin it in either direction (turned off) then you need a set of agitator dogs.
Jan 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ8220HQ0
You have to start eliminating them one by one a common reason is the spin tub mounting block if the motor comes on and clutch is driving basket drive and brake assembly than this is the problem.
Oct 04, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
