Old philips slimstar 850 washer there is water coming from underneath it seems to come from a black pipe which is neer the drain motor does any one know where the black pipe should fit ? please help
Loosing water from underneath I have looked and it seems to come from a black rubber pipe on the left side near the drain motor should it fit on something or should it be loose please help.(nothing is wet inside the machine)
  • 1294 Answers
SOURCE: AEG Lavamat 88840 update
Open up the top; check to see that the inlet tubes are firmly connected to the dispenser; possible one might have come loose. Plug off the wall socket first.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 23, 2008
SOURCE: renew washing machine front door seal
that model number does'nt come up.
Posted on Aug 07, 2008
johncaman
  • 201 Answers
SOURCE: leaking water from underneath towards the right side.
The pad is an insulation pad to keep heat in the washer. It might be worth pulling the washer out and checking the water feed and drain connections - it's a good bet one of these is leaking.
Posted on Mar 14, 2009
barkencoa
  • 3463 Answers
SOURCE: indesit 1060w leaking
It sounds like the pump or the pump inlet/outlet hose is leaking, more likely to be the pump.
Please rate my solution.
thanks.
Posted on Jul 24, 2009
  • 1738 Answers
SOURCE: My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Posted on Nov 20, 2009
Testimonial: "Thank you very much. I found out I need special tool to remove the water pump's screws. It is not diffcult do it with diagrams. "
I have a D3432 and had a blocked pipe that kept the motor running. I opened the toe kick and drained the water from the bottom tray which seemed to have solved the motor issue but after running the machine...
Well, there are a couple of places where washers can leak.
  • There are a couple of hoses underneath: from the tub to the water pump, and from the water pump to the drain connector.
  • The fill sensor switch has a length of small diameter tubing that connects to the outer tub.
  • The tub itself could rust through (as it did when my 1984 washer was about 22 years old)
  • The seal or bearing where the motor shaft goes through the outer tub could have failed.
You will have to take the back cover off and run a cycle to identify the site of the leak.
Nov 25, 2014 | Washing Machines
Replace drain hose
if u add an extension to the drain hose it will take a long time to and go down the pvc pipe. Just check for clog. by giving it for service one time may work.
Nov 03, 2013 | Maytag Performa PAV2200
Wa75b9 samsung machine not draining water
there are normally 2 pipes, take clips off and loosen pipes, normally find money stuck in them. Behind machine u'll find black,screw in plug, take off and remove all dirt and muck, coins. Loosen screws and replace pump, very easy.
Oct 08, 2013 | Samsung SW62ASP Top Load Washer
Frigidaire top loader drains water from underneath
You may have a split in a outlet pipe or a pipe has come off. If it's only leaking when it is emptying I would suggest it's probably a pipe after the pump and one that is higher then the level of water that is in the machine as otherwise the water would siphon out all the time.
Has the outlet hose been extended and have a coupling where it joins?
Dec 28, 2012 | Frigidaire FWS833A Top Load Washer
I unclogged the GD by removing the pipes underneath and replaced them tightly. GD seems to be working fine now, but water is slowly leaking from underneath the GD! It appears to be leaking from the...
The leak comes from above where water comes out.
Turn off power before touching wet electrical appliance.
Put stopper in disposal.
Fill sink with water.
Check if water is getting through the putty seal at sink connection.
Next, check if water leaks only when dishwasher runs. Dishwasher drains into garbage disposal.
Last, check tailpiece where it attaches to side of garbage disposal. The tailpiece is usually sealed with a rubber washer. When washer is old, it gets deformed, and then it doesn't seal perfectly when put back.
I use rectorseal on all tubular pipe joints under the sink.
Works on both plastic and rubber washers.
It is gooey and sticky.
Brush it all over the washer, use plenty, then assemble pipes.
The rectorseal assures that joint will not leak.
Oct 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Washer won't drain the water when it comes to Rinse and/or Spin. ??? We already unplugged it and had it ''reset'' that way..and did some trouble shooting with the 'customer service line' but no luck. We...
check you water pump.. located underneath front.... tip unit back and check it out it could be clogged turn the water off and unplug unit tip unit back a little bit so u can acess underneath it , unplug the two hoses that go to it watch for water get a pan or bucket... if that pump is defective replace it.... might have to remove the two clips that attach it to the motor... hope this helps its probably the first spot to start,, if everythin checks out okay u might need a service call.......
also look for any black shavings or a broken motor coupling,,, u can see this *** well underneath it is behind the pump attached to the motor it looks like a lil black donut and has two plastic 3 pring pieces that one end goes to the motor and the other on the tranny.... hope this helps
Feb 02, 2010 | Whirlpool LTE5243D Top Load Stacked...
I have a GE Model WJRE5500g0WW washing machine. It is two years old, purchased new. After the clothes had spun dry, water was observed on floor. Drain tube checked and okay, not plugged up. Before I open...
Normally water on the floor can be from a few places. Mostly a faulty drain pump: possibly a tear in one of the pipes: rust in the drum: possibly water in the centre which comes from the bearings.(if the machine makes a racket when spinning, then i would look at the spin bearing collum). even concider drain pipe at outlet not running out onto floor. Either tilt washer back about 45 deg. to look underneath or possibly remove panel to allow a visual of the motor and components. See if you can pick up any indecationof water having run down from a particular spot. If so rectify. Hope it helped. .Ge washers not farmiliar to me but most problems are similar.
Sep 17, 2009 | GE WJSR2070B Top Load Washer
We have been given a machine second hand, a philips slimstar 850, its quite old, and it has no on/go switch, seems simple but cant make it work!
Head over to the manufacture's website.
Typically they have a SUPPORT section where you enter the FULL model number, and the manuals are available for free download.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2009 | Washing Machines
Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Nov 26, 2007 | LG WM-2277HW Front Load Washer
Washing machine wont drain
the drain hose assembly is similar to a p-trap underneath your sink. make sure your drain hose is a upside-down J. from what you describe your hose isn't a p-trap.
Nov 02, 2007 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
