Question about Nokia 7360 Cellular Phone
Keypad jumper 7360
Open trace
I have a Craftsman garage door opener Model# 139-18059. It is a wireless keypad and wireless remotes. I go through everything the tell me and stilll cannot get door to open or close. Is there a button...
Does the wall control not work? Have you checked the house circuit breaker? Is there power to the opener? Motors very rarely go bad. If you have had a power surge or electrical storms I would suspect the logic board. You can pull this board and check for missing traces on the printed circuit.
Jun 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
Why is my 7360 keypad stuck on BUSY???!!
Something is causing a short on the keypad bus. It could be wiring, or the panel could have had a power surge. There is also a jumper on the main alarm panel board that could be shorted. Open the panel, and make sure there is no connection between the pins in the middle of the board marked RESET. If that isn't the issue, pop the keypad off the wall and make sure that there isn't a connection between the yellow and green wires. The wires are on a harness connected to the back of the keypad, so follow them back far enough to see where they connect to the wire going to the panel.
May 11, 2011 | Icon Dmp 7360-w Thinline Icon Security...
I need a nokia 7360 signal jumper diagram, pls. help me
Below is signal jumper diagram for nokia 7360 ..
Mar 22, 2011 | Nokia Cell Phones
How to remove front cover of nokia 7360
first remoce back cover then take out the front cover from bottom and remove keypad
May 12, 2010 | Nokia 7360 Cellular Phone
I forgot mu keypad unlock code. Any ideas ?
First reset to factory default setting and try.
Jan 13, 2010 | Nokia 7360 Cellular Phone
LiftMaster 1045-6: is there a fuse?
There is no fuse. Remove the logic board and look for burnt or missing traces on the printed circuit especially around the small transformer. Be sure to disconnect the power cord first.
Aug 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Nokia 7360 keypad problem
my key pad has a problem pls help me
Dec 15, 2008 | Nokia 7360 Cellular Phone
Nokia 7360 Cellular Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
