Question about Singer 7430 Sewing Machine
Singer 7430, Needle hits the bottom of the bobbin case.
All steps for cleaning have been taken, it still catches and as a result the bobbin thread does not get picked up by the needle. Moments before it was working fine. The needle broke on a pin and the thread got tangled up. I removed all the stray thread and replaced the needle with the exact same kind of needle I had been using. Any thoughts?
  • Singer Master
  • 7,365 Answers
When the needle breaks on a pin that can cause a
problem with the timing, the machine needs to be serviced
Posted on Dec 11, 2012
SOURCE: bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Posted on Nov 09, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 69 Answers
SOURCE: On my Singer Scholastic, the thread jams in the bobbin area
It sounds like it is not threaded properly through the tension disc. Try rethreading and make sure the presser foot lever is in the up position. If it continues, once threaded and with the presser foot down, pull on the thread through the needle. If it has resistance, it is threaded properly. If it pulls easily then there is a problem in the tension area. Check to see if there are peices of thread broke off in between the tension disc.
Posted on Feb 07, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Support for the 7469
Review your user's manual--if you don't have it, you can download it free at the Singer website.
Make sure that you are inserting the bobbin and bobbin case (if you had taken it out) correctly. Also make sure your needle was inserted correctly, with the flat part away from you, and it is ALL the way up and being firmly held by the needle clamp screw.
If you have done those steps and you still cannot catch the thread, it means that your timing is off and will need to be adjusted by a technician.
Jun 10, 2014 | Singer Sewing Machines
Singer 7430 bobbin case clicking sound
it's possible that the bobbin case did not get inserted correctly
or it's also possible that the bobbin case needs to be replaced, I've had to replace the bobbin case on one machine.
May 30, 2012 | Singer 7430 Sewing Machine
Singer model 7442 bobbin thread will not catch
have you tried changing the needle?
is the needle in backwards?
is the needle inserted all the way into the needle holder?
clean under needle plate & in the bobbin area for lint or loose thread
did you hit something with the needle?
Mar 03, 2012 | Singer 7422
I have had a singer prelude 8280 for a year now with no problems. now all the sudden the thread is catching in the bobbin casing. The thread on top looks normal, but when you turn over the fabric...
change the needle
clean under the needle plate where the feed dogs are for lint
make sure the thread has not come off the thread take up lever
rethread the machine
Nov 20, 2010 | Singer 8280 Mechanical Sewing Machine
The upper thread is not catching correcttly. When it does feed through the bottom corectlly it jams up after about an inch of sewing. It jams up with tons of thread.I have threaded and rethreaded cleand...
check to see if you have your needle in backwards
have you checked your needle to see if it's bent-roll it on a flat surface & see if it rolls good
check to see if the needle is blunt-makes a popping sound when going thru fabric
check to see if the thread is getting caught on the notch of the spool of thread
check to make sure the bobbin is not warped
check to make sure there are no burrs on the bobbin case
check your upper thread tension
Aug 21, 2010 | Singer 3116 Simple
I think the timing is off on my singer 7430 -- it keeps breaking needles and I can see where the needle hits the bottom of the bobbin casing when it is in the fully down position -- any quick fix?
Drop-in bobbin?
Refer to the maintenance section of the manual for cleaning.
Raise the needle to it's highest position and remove the bobbin and bobbin case.
Clean the shuttle and replace the bobbin case, noting the graphic in the instruction manual for aligning the case into the shuttle.
Turn the handwheel to see if the needle now clears the outer edge of the bobbin case.
Mar 29, 2010 | Singer 7430.CL Computerized Sewing Machine
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Bobbin not picking up through the needle part of the machine
Oct 14, 2008 | Singer 3116 Simple
Singer 7430 Sewing Machine Logo
125 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
