Question about Electrolux Washing Machines
Manual for aqualux 1200 washer/dryer EWD 12141
Instruction manual needed
barkencoa
  • 3463 Answers
SOURCE: User manual needed for Hoover washer/dryer
Hi.
In you browser box type in Hoover user manual.
Then scroll down to Hoover after sales service instruction manuals.. Click on this, and then on Laundry.then on Waher -dryers, follow instructions
You will find your model listed there,.
Please leave good feedback.
Thanks
Posted on Nov 29, 2008
keithkalish
  • 146 Answers
SOURCE: aqualux manual
This is a link I think you can search and download a manual for your machine, you need to be accurate in what model you have in order to find the manual
http://www.frigidaire.com/manuals
Posted on Sep 16, 2009
mnwarfield10
  • 452 Answers
SOURCE: electrolux aqualux 1200 water leaking from door
have door gasket changed .....01179512835
Posted on Dec 30, 2009
  • 174 Answers
SOURCE: washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Posted on Jul 20, 2010
livewire874
  • 618 Answers
SOURCE: I have an Aqualux 1200 washer/dryer. After the
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
Posted on Nov 18, 2010
My ewd 12141 trips the electric
If this machine is new, the circuit may have inadequate amps.
If the machine has been in place for a while, and this is a new problem, you may need an electrician to test the circuit breaker. They do wear out and need replacement.
Oct 12, 2014 | Electrolux Washing Machines
Programme dial on Electrolux ewd 12141 has worn off and the manual does not have a picture. Can anyone help me??
check on e bay or contact manufacturer for replacement. failing that try searching online for an image of said dial and mark on setting you use with a permanent marker pen
Mar 08, 2012 | Washing Machines
I have an Aqualux 1200 washer/dryer. After the wash cycle the fabric conditioner compartment of the tray is full of water and the fabric conditioner appears not to have been flushed into the machine
Nov 18, 2010 | Electrolux EW1200i Front Load Washer /...
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
Jul 20, 2010 | Electrolux Washing Machines
Electrolux aqualux 1200 water leaking from door
Dec 30, 2009 | Washing Machines
Aqualux manual
Sep 16, 2009 | Washing Machines
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Washing Machines Logo
75 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
