Can my new (2nd hand) New World Classic 110 DFa be connected to a normal 13amp electrical socket? Or does it need its own higher voltage power feed direct from the fuse board?
  • 7,627 Answers
Wrong category
Posted on Dec 11, 2012
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Power supply between battery and 110 voltage
You can download the manual from this page:
http://safemanuals.com/user-guide-instructions-owner-manual/DELL/INSPIRON%20B130-_E
I'd like to help you with your problem but I can't see what the power supply/connection problem relationship is. Perhaps the manual will help-
Posted on Oct 05, 2008
  • 4088 Answers
SOURCE: Have acer aspire 3690 - power socket is detached
Use epoxy glue to fasten the socket to the board. I assume that you have a proper soldering iron (small grounded tip, not a soldering gun), and know how to use it. After the epoxy has cured, trace the damaged tracks back to another solder connection, then solder an insulated (about #24 or #26) wire to that point and to the appropriate connection on the power jack. There should be a maximum of three wires to install. If you make the proper connections, it should work as before. Good luck!
Posted on Feb 05, 2010
Does it need 6mm hard wired cable or can it be used with standard 13amp plug via ring min
hard wired is the normal way ranges are done unless they are gas .then the electric can be lighter gauge
Apr 23, 2016 | Ovens
Charger connection for hp mini not working, I thought it was a short in the cord but it seems to be the connection inside the computer.
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 21, 2012 | HP Pavilion 110-1030NR Notebook
The fan has stopped orking on my new world oven
I have no worked on a new world oven, but i will assume you speak of a convection oven.
Typically convection ovens have a door switch a motor and a run/start capacitor which helps the motor "turn over". I suggest, you have the oven cool, remove anything blocking the convection motor. Take your hand and spin the wheel, then while its spinning turn it on. You may have to try counter or clockwise. If you cant spin it at all, you have a bad motor, if the motor starts up with your manual assistance, the capacitor is bad. If there is not even a hum, a door switch is faulty, that or the motor has a thermal overload (usually a red button on the motor that needs resetting).
Dec 19, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
My front right hand burner is not heating up
Take another burner out and plac it in the righ front spot. If that one heats up, you need to replace the burner. (they pull right out)
If the other burner does not work, then you should check for a loose wire going to the socket that the burner plugs into. If you have a voltage meter, you can check for voltage and trace it down from the socket, to the other components untill you locate the source of the failure.
Oct 15, 2009 | New World 60ECHDGm Electric Kitchen Range
Does a moffat oven need a 30amp cooker socket or is it ok on a 13amp plug
Unless your talking about one of those tiny, table top ovens, dont use a 13 amp socket / connection.
An electric oven must be connected via a 30 amp SUPPLY - the socket is just the connector at the end of the cable that runs from the fuse / breaker board. A 30 amp supply will use a much thicker cable capable of handing the higher currents.
Whilst a very basic oven may draw less than 13 amps current when operating in some modes, most will draw well in excess of this depending on what facilities they have, e.g. bake and grill at the same time, or maybe a combi-oven - one that can bake and microwave at the same time.
Oct 03, 2009 | Ovens
Battey not charging, red light flshing
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Oct 02, 2009 | Dell Inspiron 1525 Laptop
Broken the mains power cableand dont know were to get a new one
Help is at hand. but you do need basic electrical skills for the first solution and handy soldering skills for the 2nd.
sol1
If you cable is fraid then cut the cable and fit an inline connector. If your not sure here is a link.
http://www.4barmey.co.uk/cgi-bin/product.pl?PID=1078065&item=783496&section=67924&path=67885,185197,67893:185866,67924
Sol2
Total replacement of power cable and plug. you will need to buy new flex and plug. normally two core flexible (multicore not solid core) cable.
Open up the rear case to the tv and keep all screws. DO NOT touch the end of the tv tube as high voltage lingers a while after unplugging. You are looking / tracking the power cable where it fits to the tv motherboard.
Take a standard solder iron and remove each cable in turn. noting the colour and positions. Prepare your new cable feeding it into the casing and motherboard to suit. Apply flus and solder to secure each new cable in place. Hold cable while it sets and cools. CHECK there is no solder connecting these cables together for obvious reason these DO NOT connect together.
Replace casing and all screws in reverse order.
You should have a good to go new cable and a tv working fine.
AndystUK
Aug 31, 2009 | Crown Televison & Video
No charge
You'll need to test to see if you are getting voltage from the brushes. This is a live test so, using something like alligator clips or such on the metal bracket of the brushes for your volt meter is a good idea. Simply start your generator with the volt meter leads attached to the the brush holders or exposed electrical connection to the brushes and see if they are producing electricity (120vac or greater). No voltage then it's your brushes, field, or stator. If they are good check the output of the voltage regulator. If it to does not kick down any voltage above 120 then it's your problem.
Note most cheap generators do not have a voltage regulator. All generators depend on the correct engine rpm to achieve normal voltage. 3600 rpm is the correct speed on a two pole generator to produce 110 to 125vac and 60hz (normally found on gas generators). 1800 rpm is the correct speed for four pole generators (normally found on diesel generators). You may set your rpms slightly higher to ensure that it's maintained underload ie 3750 for gas. Diesels usually have very good governors and don't need to be set higher.
Mar 29, 2009 | Coleman Powermate Powermate 5000W...
Oven connection
I have tried to locate electrical information on your oven from here in the USA. I was not able to locate the electrical requirements for your Zanussi ZOD 330X. If it is typical voltage for ovens like ours in the USA I would say no and that the power should be 240 volts and 50 ampere breaker. But to be sure you should locate a local supplier for your model and ask them first. This will prevent any incorrect answers from someone that is not familiar with your local requirements. Thank You, Sea Breeze
Mar 25, 2009 | Zanussi ZBF360X Electric Single Oven
Power to power carpet head
it sounds like the spring on the cord reel let go. difficult to reinstall. it may have been broken already and that is why it came off. it is rather meticulous trying to work on a cord reel. many can't be disassembled without breaking
Aug 09, 2008 | Miele S548 Bagged Canister Vacuum
Computers & Internet Logo
David Payne
David Payne
