Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
F-08 half way through any cycle now and then comes up with f-08 message, turning off machine and restarting it seems to fix but is there a solution to this!!! Thanks
  • 67 Answers
When f-08 flashes are any of the other led's flashing if so which ones.
Posted on Jun 28, 2007
SOURCE:
Why is no water coming through for coffee
What do you use to clean the machine? White vinegar s a good cleaner for coffee machines. I suggest you place half vinigar and half water in machine and run it as usual- maybe a few times with the vinegar and water. Then place some baking soda with water to neutralize the vinegar.
May 05, 2014 | DeLonghi Magnifica Coffee Makers &...
E20 error message
maybe you should just get a new washing machine
Dec 11, 2013 | Washing Machines
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
When I turn on my HP designjet T 1100 I get error message 08:11
turn off printer, disconect hdd from pcb, turn on then printer beeps, turn off mount hdd back, turno whait ;).
Mar 19, 2009 | HP Designjet T1100ps Printer
Error message on print screen of 114 08
The book says nothing about this error except turn off machine for 30 seconds and try again. If this dosen't work try unplugging machine, removing the batteries and then restart. CAUTION THIS WILL CLEAR ALL MEMORY!
DicktO
Jul 29, 2008 | IBM Wheelwriter 30 Typewriter
On my hotpoint washing machine half way through the cycle error code F-08 appears. how can i fix this?
Replace the on board computer,Sorry !! Please Rate This !!
Thank You !!
Jun 09, 2008 | Washing Machines
F-21
replace the contol board
Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi progress 1200 WASHER DRYER
This means that the filter is clogged. Get a towel (or two) in our case, and then unscrew the filter. It'll be full of lint.
Dec 26, 2007 | Washing Machines
The top half of the agitator (near the fabric softner comp) is skipping while it is in wash cycle
yes the top half seperates from the bottom half inside the top half are 4 little parts called dogs. the part number is 241341. replace the dogs to fix it
Nov 27, 2007 | Kenmore 22932 Top Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
230 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
